The manual suggests: check the solenoid in tech mode but how? check cassette/MP knock up plate and springs? Check paper separator pad but where is this? I have tried cleaning the pick up roller. Thanks
SOURCE: HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
SOURCE: Okidata-B6200-
Check the reg sensor for dirt etc and paper setting is correct in the paper tray
SOURCE: Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
