Replace door gasket, adjust hinge or give up?
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
SOURCE: side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
SOURCE: GE profile: side by side; refrigerator door won't
clean gaskets and close door gently . if that don't work hinges could be sprung
SOURCE: Refrigerator door does not stay
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
SOURCE: freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
