Question about Samsung HL-T5076S 50 in. TV
How to replace "Fan #2" in a Samsung TV model # HL-T5076S
Posted by Harry Benedict on
5 Related Answers
Anonymous
SOURCE: samsung ht-z310 home theatre audio problem
All,
I submitted an earlier request trying to determine why surround sound wasn't coming through all speakers when playing my TV.
Looking further into the Samsung site I found out that you MUST connect the optical cable from the home theater unit to the CABLE BOX and not to your TV to get surround sound...I'm currently in the office but will change the connection once home...try connecting to your CABLE BOX instead of your TV and it should resolve the problem.
Posted on Mar 23, 2009
Anonymous
SOURCE: samsung remote code for dish net. not working
Try 069, 070.
Pick your Mode, then Hit the set button at the bottom, then type in the numbers and you should see the mode light up 4 times if done correctly. Hit power and see if it goes on. I think the Frequency changed though.
Posted on May 14, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: i replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Posted on Dec 09, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Posted on Dec 24, 2009
Testimonial: "Your solution was very timely and helpful. Thanks"
easyab
easy alberta
  • 132 Answers
SOURCE: NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Posted on Apr 23, 2010
HL-T5076s changes inputs by itself
The side buttons panel might not get proper voltage. Check it. Replace the side control panel card.
I have a SAMSUNG model HL-T5076S flat screen TV. A blue light stays on at the bottom of the set after I turn the TV off
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
2helpful
2answers
Dark picture with white dots
The white dots are caused by a defective DMD chip. Samsung is covering the cost to repair this problem. Call 1-800-samsung and they should set up the repair with the closest service center. A dark picture could indicate that the Lamp is about to go out, mention this problem when you call Samsung.
Samsung HL-T5076S Tv blows bulbs about once a month
You're definitely not having a lamp problem. It can be your ballast not providing your lamp with the correct amount of voltage. Lamps should last a minimum of 1 to 3 yrs. specially if you bought a Philips lamp.
Look into your ballast. Samsung has a history with this ballast.
Tv turns off
Replaced swolen capacitors on power board.
1helpful
My samsung HL-T5076S won't power up.
Ok, i just realized you stated that you get no stand by light. this is a dead power supply board. you will need to replace this power board in order to restore proper function in this unit.
Samsung HL-T5076S 50 in. TV Logo
Ekse
Demonic-2011
Demonic-2011
