Question about Grinders
WHICH WAY DO THREADS ON MAINSHAFT RUN
Trying to disassemble an old bench grinder to replace disc and brush. but not sure whicy way the threads on mainshaft go. on the brush side(right side). it is regular thread, counter-clockwise to loosen. not sure on disc side(left). this is an old reliable bench grinder(40+years old). with new disc and brush it could give me many years more service.brand unknown as motor/brand plates have erased by now.
thanks
gilberto rodriguez
[email protected]
Posted by gil_rodrigue on
Anonymous
  • 986 Answers
Look at rotation. The opposite of each end will be the way to loosen it. that way as it rotates the nut will tighten
Posted on Sep 13, 2009
Samuel Charles Spriggs
    President:
  • 1,489 Answers
If the right side is a right-hand thread, the left side is opposite that -- left hand thread.
Charlie
How to put on a wire brush on a craftmans 6 inch bench grinder 21126
There is a left handed thread and a right handed thread on the arbors.
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Aug 03, 2015 | Bench Grinders
How do I change a grinding wheel to a Wire wheel on my new grinder # 37823
Removal
Left Hand Side (LH)
Installation
Left Hand Side (LH)
Feb 14, 2015 | Grinders
Delta bench grinder model 10 bges are the threads l/h or r/h
The right side should have right-hand threads, the left side should have left-hand threads.
Feb 01, 2014 | Delta ShopMaster 8in Grinder with Light...
How do solve gas leakage problem
1.Disassemble the leaking fitting. Be sure to have container ready to catch any leaking fuel.
2 Clean the threads on the fitting. Use a wire brush and/or solvent to remove grease and dirt from the fitting.
3 Apply the thread sealant to the threads. Brush or stretch the tape or liquid in the direction of the threads. Make sure the threads are thoroughly covered, but do not go over the end, where the fuel may be contaminated with the sealant.
4 Reassemble fitting as you normally would. Test to ensure the leak has stopped.
Oct 15, 2011 | Dometic RM2620 Refrigerator
How do you tighten the nuts when changing the wheels on a 6 inch craftsman bench grinder. Thank you...
Clamp the shaft behind one wheel with 'Channelock' or 'Visegrip' pliers, then tighten both nuts. Check the new wheels for 'off-center' running by spinning them with your hand. They may fit the shaft tight enough that there is no centering adjustment--use a 'wheel dresser' (either a stone type or a multi-wheel type) to true up the wheel so that there is no radial wobble. Hope this helps!
Oct 23, 2010 | Craftsman 10" Bench Grinder
How to stop shaft from turning to remove nut and replace wheel
If you put a wrench on the nut on the other end of the shaft, you have a 50/50 chance that the nut you want loose will come loose. If the wrong one comes loose, you can remove that nut completely (and the wheel) then take the nut with you to the store to buy another one. Then put two nuts back on and tighten them together as a jamb nut. Then try again. If the wrong nut still turns, you have to tighten the pair of nuts together tighter. good luck
Oct 08, 2010 | Craftsman 10" Bench Grinder
HOW DO YOU REMOVE NUT TO REPLACE WHEEL?IE STOP SHAFT FROM TURNING,THHAKS
Hi edward, looks like you posted the same question twice. I already answered the other one. good luck.
How do I change a brush? I can't get the axle locked to get the nut off. Can you help me?
Remember if you are trying to change the left side it is a reverse thread nut. You would turn it clockwise to loosen. IF it is very tight, put a wrench on both sides. IF the right side comes loose, remove brush/grinding wheel, and re-install nut, with an extra nut locked to the first one, the put a wrench on both sides again.
Sep 30, 2010 | Sears Rockwell 8 in. 3/4 hp, 5-amp Bench...
Have tried everything, can't get one of the grinding wheels off.
On a bench grinder the wheels turn towards you. This means the grinding wheel on the right side, has a right and nut, and the left side has a left handed nut. If you're trying to remove the left side turn the nut counter-clockwise
Aug 16, 2010 | Delta Grinders
Delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
Aug 29, 2008 | Delta ShopMaster 8in Grinder with Light...
Grinders Logo
192 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
