Question about Miscellaneous
What size are the brushes for the Craftsman 4x24 model 31511782 belt sander? Where can I buy them?
Posted by Walter Finn on
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: power tool switch
Call this number they are in ohio but have in the past been able to help out 937-325-6441 give them the part number and tell them you have not been able to locate the part
Posted on Dec 04, 2008
slave2aslave
Terrie Thiessen
  • 302 Answers
SOURCE: Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
Posted on Oct 10, 2009
Anonymous
SOURCE: need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Posted on Oct 22, 2009
Anonymous
  • 760 Answers
SOURCE: How do I obtain an owners manual for Sears
Click on this link:
http://www.managemylife.com/mmh/owner_manuals/19852/CRAFTSMAN-Sander-L0807584?brand_name_search=31511721+CRAFTSMAN
If this link dosen't work go to : www.searspartsdirect.com enter your model number and view the parts list. Then click on the button to the right that says manual
Posted on Jul 21, 2010
Anonymous
SOURCE: Finding parts for Craftsman 4x24 sander model
craftsman belt sander just stopped - does craftsman still have life time warrenty?
Posted on Aug 01, 2010
Just now found this post and have the same problem: My beloved 5910 switch is NLA (23-66-0491). Anybody out there have a more current solution? usulbooks on Oct 12, 2008 I like my Milwaukee 4X24 belt...
this switch can be matched up with another one. Call this number for a repair center in Cincinnati. 513-621-2183 and see if they can help. There is nothing special about this switch that you can't find one that will fit. Let me know if you still need more help
Sep 08, 2011 | Tools & Hardware - Others
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
Need a manual for a Craftsman belt & circular sander
Oct 21, 2009 | Tools & Hardware - Others
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Power tool switch
Oct 12, 2008 | Tools & Hardware - Others
Miscellaneous Logo
102 people viewed this question
Top Miscellaneous Experts
Steven Wander
Steven Wander
Artur Heise
Piers Carter
Piers Carter
Are you a Miscellaneous Expert? Answer questions, earn points and help others
