It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
I just came home after being out of town for several months and my garbage disposal just hummed. I tried the reset button. One thing that I tried (that I read else where) was to put a broomstick in it and bang it a fe times (with it off of course). I worked like a charm!
Sounds like the motor is shot. Generally if the motor will turn then there is not much you can do. Check the warranty on the unit. Warranty varies from one year to 10 years. If it is over ten years old * would just replace it.
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
I was wondering, since this is related, does the stuff you put down your disposal ever make it to the garbage dump, or does it go out to the ocean?
