Question about home Audio Players & Recorders
My sinotec hts-518 home theatre does not turn on
5 Related Answers
Anonymous
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Posted on Dec 08, 2008
Anonymous
  • 19 Answers
SOURCE: DVDs not reading
have you tried cleaning the lens? do not use cotton buds or touch the lens , use a dvd lens cleaning cd , as there may be dirt on your lens or the discs are dirty, if this does not work it is possible that you require to have the lazer replaced. good luck
Posted on Apr 28, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: Philips hometheatre system HTS3555 stoped working
Upgrade again with the HTS turned on.
Posted on Mar 22, 2010
Norman Worley
  • 1273 Answers
SOURCE: I just bought a Samsung HD LCD 32 in TV and want
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Posted on Nov 29, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: RECENTLY I HAVE BOUGHT A
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
Posted on Dec 21, 2010
Testimonial: "Dear Sir, Thanks a lot for suggestion. Without your help it would not have been possible for me to operate the my system "
Philips HTS 6600/12 Home Theatre System HDMI does not open the DVD door.
DVD sledges work by a rubber belt that in your case might have broke or come off. It's very easy to replace. Find the original belt. Measure the diameter in MM (approx) and do a Google search for "Drive belt XX MM".
Get the nearest to your size.
Jan 21, 2016 | Philips HTS 6600/12 Home Theatre...
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ok
Dec 21, 2010 | Philips HTS-3565 Theater System
Mar 22, 2010 | Televison & Video
The region is 4 and would like to watch all regions dvds Do you have the code to unlock my Philips HTS 3578w
Try this:
Switch player on
Press eject on the remote to open tray
On the remote, press 9,9,9,9 then 0
Region:0 should appear on the screen
Switch player off, then on again
Should now be multi-region
Credit goes to rimcius from www.videohelp.com
Jan 28, 2010 | Philips HTS 6600/12 Home Theatre...
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
35 people viewed this question
Top home Audio Players & Recorders Experts
Kenneth Walker
Marvin
Marvin
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
