Washing Machines Logo
j
john Posted on Aug 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung WA13G7Q1 machine runs all cycles until it comes to the spin cycle then the machine stops. what could be the cause of this?
The machine starts to drain in the spin cycle then the cycle stops. not full load or heavy items in drum. wash cycle is fine.
Michael
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Sep 14, 2019
Michael
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
2063
Points
19
Check to see if your washing drum feels loose
keith jones
Level 3:
Master:
  • Samsung Master 747 Answers
  • Posted on Sep 08, 2019
keith jones
Samsung Master
Level 3:
Master:
Answers
747
Questions
Helped
314302
Points
1478
If all the water has drained the most common fault is the brake motor which releases the drum so it is free to turn,with the back off and a torch you should be able to see the lever and cable being retracted id nothing happens on spin thatd your problem
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on May 18, 2007
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
A
Anonymous
  • Posted on Nov 25, 2007
SOURCE: SPIN CYCLE
Front load Neptune model
Anonymous
  • 1073 Answers
  • Posted on Jun 13, 2008
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 04, 2008
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 19, 2010
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Samsung wa13g7q1 cycle stops at 55 minutes
Please turn the cycle dial a bit more clockwise until the draining stops. If the problem persists, please power cycle your washing machine by turn off it's power for 1 minute before restoring the power.
Thank you.
Samsung Toploader WA13G7Q1 siezes when entering rinse / spin cycle and the water does not drain. Can this be repaired / replaced?
The plastic hose to the water level sensor switch can get suds or dirt stuff in it and causes issues like this. Take the hose loose and blow through it then run a couple plain hot water cycles to clean out access soap film and residues.
I have a Samsung WA13G7Q1 top loader giving me a DE on LCD when spin cycle starts then just stops.
DE is an error relating to the lid switch/lock not working, if it cant sense the lids shut it wont spin, it could be as simple as the magnet in the lid has moved or the more likely cause is the lid switch has died, it will require further inspection or you could just order the lid switch and see how it goes
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
3helpful
Wa13g7q1 washes but doesn't want to spin; code de appears with an alarm, pls help
Replace the pressure switch, and run a cup of white vinegar thru a cycle with no laundry in the unit.
4helpful
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
2answers
SPIN CYCLE
need more information is it top load or front
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
