Question about Refrigerators
Hisense double door fridge, light not coming on when open right door, left door the light comes on. Where is the sensor to turn the light on. There is no traditional push switch. Thanks
4 Related Answers
Eddie Lenoir
  • 38 Answers
SOURCE: dome light wont come on when door is opened
look for the fuse box...
Posted on Dec 30, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
meme_bebe123
  • 6 Answers
SOURCE: Vestfrost W155 Wine Cooler: Door
palit
Posted on Mar 09, 2011
ImJustAvg
  • 2006 Answers
SOURCE: I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Posted on Jan 19, 2012
What might the problem be and how can I solve it?
The evaporator is iced over. Simplest solution is to shut the unit off, clear all items out of it and let it sit open for 24 hours. Afterwards, restart the refer and allow to run for 3 hours and check for proper cooling in the fresh food section.
Jun 22, 2016 | Frost Refrigerators
Where does the water filter go on my fridge model rf26hfendsr?
Depending whether it's a single with double door possibly a 2 door with 2 drawers you need to open the doors and look either in the center or on the right or left to see if there's a black cap that will twist off to openthe filter chamber usually the filters pressure fit into that soon as you open the cap will come out with the filter attached to just have to remove the cap and insert the filter into the chamber and replace the cap
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Feb 05, 2016 | Refrigerators
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
Dec 28, 2014 | Hisense RS731N4AC1 Stainless Steel 562 l...
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
Fridge light takes 2.5 sec to come on
Hi!!!
Have you cleaned the switch actuator? It is usually located on the door frame since it is activated by the door. Some times accidental spills will keep the switch from working correctly.
Good Luck
Mar 11, 2010 | Refrigerators
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge is freezing food
YOU HAVE A BAD THERMOSTAT,REPLACE,MAKE SURE DRAIN IS CLEAR TO,THANKS-MIKE
May 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Whirlpool gold fridge model GD5SHAXNSOO
Have you got a screw loose. One which holds the door light switch. is it the switch which buzzes?. I had a fridge which didn't get cold. When I scrapped it I found that the retaining ring for the switch was not tight enough and r4ealised that the light had been on when the door was closed.
Apr 08, 2008 | Refrigerators
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
