Washing Machines Logo
D
Denis Tanigawa Posted on Aug 29, 2019
I have a Maytag washer, model # MVWC300BW1. During the spin cycle, the tub rotates but it shakes the washer violently and hits the front of the machine. What could be the cause of this?
I've leveled off the washer front to back and side to side.
andrew uy
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 29, 2019
andrew uy
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1666
Points
21
5 Related Answers
A
Anonymous
  • Posted on Aug 09, 2008
SOURCE: kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Anonymous
  • Posted on Mar 24, 2009
SOURCE: Front load washer shakes violently during spin cycle
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Anonymous
  • 750 Answers
  • Posted on Apr 03, 2009
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
pumpkinman
Steve Sweetleaf
  • 1212 Answers
  • Posted on Jul 01, 2009
SOURCE: shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Anonymous
  • 254 Answers
  • Posted on Jan 28, 2010
SOURCE: Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
1helpful
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
2helpful
2answers
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
I have a Maytag (Model MTW5770TQ0) washer. It
yes it sounds like it try this when running open lid if it
does what you say its doing then the transmission needs to be replaced this contains the clutch and it may be cheaper to replace the washer call a repairman
2helpful
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
7helpful
3answers
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
2answers
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
1helpful
2answers
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
1helpful
2answers
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
