If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
It's likely that the door switch has failed, or stuck in the depressed position from grease or your oven cleaner spray solution. To correct this problem, remove the door switch and inspect with a multimeter for continuity connection.
It will take some time for it to unlock. The lock after self cleaning is controlled by temp. The temps during self cleaning are over 900 degrees and after self cleaning it will take several hours before the oven lock will release. Don't try to force. If after 3 hours it has not unlocked you can try disconnecting power for 2 minutes then reconnecting to activate the self cleaning motor assembly. Good luck and thanks for using Fixya
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch
motors, sensor probes and even the electronic controls can be destroyed
by this operation. Suggest oven cleaner method.
