Question about Schlage Locks & Locksmithing
Schlage sense works on left hand door won't work on right hand door
Posted by Timmy on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: change right hand door ,to left hand
Not sure with this model but most time you can and I'm sure this is no different, look at the screws holding the hinge bracket, there should be identical screw holes to match on the opposite side.
Posted on Nov 18, 2008
Anonymous
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
Anonymous
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Posted on Jun 09, 2009
richochet
  • 1026 Answers
SOURCE: left turn signal works / don't work, brake light
possibly flasher unit faulty
or turn signal switch
Posted on Feb 22, 2010
loriwilaon
SOURCE: I have a two month
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
Posted on May 13, 2011
Schlage keypad door lock
The wiring on the BE series is prone to getting pinched. Open it up again to make sure that you haven't pinched or cut a wire, then make sure that you plugged the two halves of the wire back together again when you reinstalled it on the door after you removed it to find the preset code. If both of those things are done and the lock still doesn't function the only thing left is the battery. Replace it with a new alkaline battery and the lock should work. If it does not contact Schlage and their great customer service team will help you out!
Dec 28, 2017 | Schlage Locks & Locksmithing
Keyless schlage lock opens when schlage button is pushed
  1. Remove the two screws on the back plate.
  2. Disconnect the battery
  3. Remove the two screws on the inside of the lock so that you can remove the entire lock.
  4. Once you have removed the lock from the door take the backplate in hand
  5. Right above the orange plastic piece there is a small black egg shaped cam.
  6. Turn the black egg shaped cam to the side and then turn it back down so that the arrow is pointing down.
  7. If you do this right the deadbolt will stay in the unlocked position. The deadbolt will not retract when you turn the cam because it should be completely disconnected
  8. Once you do this correctly you will reinstall the lock in the unlocked position.
This also will fix the light not coming on when you press the Schlage button.
Dec 15, 2017 | Schlage Locks & Locksmithing
Schlage keyless door lock wont lock
Can you provide more details? I've had similar problems with Schlage Sense and August Smart Lock. So I might be able to help you.
The first thing we should try is reseting the lock and try setting it up as brand new one.
Mar 21, 2013 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
Lock won't work
Change your battery & reprogram your lock. Follow this link.
Give this a moment to load:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
May 17, 2012 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
I need to set/change the code on my Schlage lock but the sticker is completely unreadable.
I do not believe you will be able to reprogram the lock without the programming code, usually found on the sticker (unreadable, in your case).
Therefore, I urge you to call Schlage directly-they may be able to help you. here is the contact information:
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
You are right about the support link going 404-It used to work. Get there by going to:Schlage.com
and clicking on "For your home"
Mouse over the "Service & Support" link, then go down & left click on "Instruction & Manuals". There ya go!
Feb 14, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
I don't know the model number of the lock. It was installed in 1993.The latch broke. I got a new latch but cannot get it to work. Either it won't go or the handle slips. It does not have a key....
Start on this web page to identify your lock:
http://consumer.schlage.com/Products/Pages/category-landing.aspx?category=Electronic+Security
Then go to this page for links to the proper instruction and programming manuals and videos for your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
If you're still having a problem or need parts, here is the contact information for Schlage Customer Service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Hope this helps!
Jun 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
I have a two month old Schlage door lock recently I went to get a new copy of Schlage keys. I tried it one time it work and a week pass suddenly my new keys doesn't work and even the original key, it...
May 13, 2011 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Door has worked fine for years with a Schalge camelot electronic lock. Tonight it stopped working and you could not open the door with the inside or the outside handle. Key would not open door either. I...
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Apr 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I have 2 schlage door handles that are suppose to be able to be used right or left handed. I can't get the handle to turn to the opposite direction. (if it is set to be installed as right handed, I need...
How does the door handle even know if it is in a right or left handled door?
The handle should retract the latch with a quarter turn clockwise OR counterclockwise, so it should make no difference at all.
The only thing that is right or left handed is the direction the latch bevel points, so that it will retract when you push the door shut.
And the latch has nothing to do with the handle.
Are these circular door knobs, or is this a handle that has to then point at the hinges?
Because it seems to me that if the direction the handle points is the problem, you simply put them on the wrong side of the door.
Aug 17, 2010 | Garden
How do I flip the handles around, or is there a seperate one for right hand and left handed doors.
There are retaining screws on one side that hold the outside to the inside or vice versa. You will also have to switch latch so that tapered end goes into frame at opposite angle that it is now. Just turn it upside down.
Jun 14, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Locks & Locksmithing Logo
168 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
