Question about Furniture
I have a Duran manual recliner that will not let me stay reclined, how can I adjust the tension on that chair so reclining is easy and will stay without pushing me up.
Posted by Gail McNamara on
iandunn_tms
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 168 Answers
Flip the chair over on its back.
You will see a frame and spring...
Loosen of the spring that's attached to the recliner frame.
You will need to undo the locking nut first.
Wind back the adjuster a couple of turns and do the locking nut back up.. not too tight.
Should be good now.
If not repeat steps to loosen adjuster more.
You may need to tighten adjuster if connected to leg not frame.
Posted on Aug 30, 2019
5 Related Answers
NewMerlin
SOURCE: front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Posted on Jul 28, 2008
Anonymous
SOURCE: seat recline
its behind the saet... pull it up until it snaps and then pull the stroller seat down and release
Posted on Aug 11, 2008
Anonymous
  • 321 Answers
SOURCE: the reclining lever for my has broke off cant
well lets not start with visegips .
the lever needs to be removed by removing the screw and removing the lever.
go to the dealer to get the new lever and put it on.
Posted on Jun 12, 2009
Liz Wanden
  • 419 Answers
SOURCE: Seat recline buttons stuck
I would suggest that you return this for a repair to your retailer, if this is in warranty (2 years).
If not, you can dismember the white (retangle) buttons quite easily to enable the release of the seat frame,. On each button there is a small clip either side that you have to push in together. Inside each button is a spring, just make sure that you keep the spring for when you have put it back together. It does sound like the spring has just become dislodged.
I hope this helps.
Posted on Sep 14, 2009
deborah catt
  • 14 Answers
SOURCE: seat on pushchair, wont stay up, keeps falling back into recline position - graco cleo air
Hi, i had this problem. If you put you hand down the back of the seat there is a strap with a 'holder' on it. If you tighten this as far as it will go this should hold it up. To lie it back again just release the 'holder'. Sound funny but once you look at the rear strap you will see what i mean.
Posted on Jan 05, 2010
Our chairs will not swivel properly. What can we do?
SUSAN, WHAT KIND-OF CHAIRS?? TURN CHAIR UP-SIDE-DOWN SPRAY WD-40 INTO BEARING AREA THAT SWIVELLS ,SHOULD FREE-UP AND WORK LIKE NEW, YOU HAVE TO MAINTAIN THESE CHAIRS EVERY SO OFTEN! THANKS
Jan 24, 2016 | Ekornes Stressless Recliner Chair Personal...
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Is there a adjustment to bring the back up instead of falling back
if you turn the chair upsidedown you will see two wing nuts on sliders just tighten them
Sep 17, 2014 | Furniture
The spring snapped on lafer recliner chair
I bought replacement spring at Lowes
This was Hillman brand replacement spring
Five eight x three and a quarter x 072 inch type
2 springs per pkg works great
Apr 06, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
Aug 09, 2012 | Furniture
What are the different types of leather office chairs?
Leatheroffice chairs include: Adjustable Leather Task Chair, Executive Mesh Chair,high back traditional executive swivel chair, and leather plus posture taskchair. For more details on these chairs, go to this website: http://www.ehow.com/list_6105999_types-leather-office-chairs.html
Jul 30, 2012 | Furniture
I want my living room to be comfortable and attractive. Which kind of chairs should I put there?
In order to decorate your living room well, you need tothink about the function of the room. Yes, you want it to be comfortable and attractive but what is thepurpose of the room? Is it the room yourfamily will gather in to watch TV, is it only used as a lounge when guests areover, will it double as a guest bedroom? Once you have figured this out, youwill be able to get a stronger concept of what kind of chairs you should havein the room.
May 29, 2012 | Furniture
Furniture Logo
130 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
