Question about Liebherr Freezers
Why is my liebherr 1466 freezer raising its temperature unless the superfrost is on?
With superfrost on it goes to -18 celcius but when superfrost switches itself off (after 40-60 hours)the temperature rises and the alarm sounds
Posted by ian cornelius on
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Posted on Dec 27, 2007
Anonymous
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
Anonymous
SOURCE: Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Posted on Aug 06, 2009
geoff hunter
  • 4793 Answers
SOURCE: I own a liebherr GNP2076 frost free upright frrezer
freezers do not normally go wrong too often so your going south is unusual.liebherr have given you a very good responce that some makers would not even dream of,i would recomend that you take up their offer as the chances of another problem are slim to zero...(in european law, it is you that has to prove that an appliance has a "inbuilt fault"to get anywhere.)
Posted on Apr 07, 2010
Raz Mataz
  • 389 Answers
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
My Woods upright freezer MU07W running great for 9 years. Will it continue to run if I decide to place it outside on the balcony where temperature goes down to 20 below F or to max of 90 F plus?
Not the best idea. We had one in our garage where it got cold but not that awful cold. Not a good idea unless you want to take a chance.If the unit shuts down for a long time because of the cold the system could freeze or seize up.
Feb 05, 2017 | Woods Upright Freezer MU07W
Why do both green light and orange light stay on all the time?
Without knowing much about Frigidaire , I would say at a guess that the green light would mean there is power on and the orange would be that the temperature isn't down to what you have selected yet. Most freezers have these 2 lights or a display showing the same. Check that the freezer hasn't frosted up and the food has frozen correctly. If you have a thermometer, most domestic freezers should run at around -18 degrees celcius. If its a larger type for long term storage, the freezer would normally run at around -20.
Apr 11, 2016 | Frigidaire Freezers
The freezer is to cold
I do assume this is in Celcius.
-20C is about the right level for a three-star freezer.
From Google:
  1. Domestic freezers have a star rating indicating the temperature they are designed to operate at. On the packaging of a frozen food there is guidance stating how long the food can be stored using freezers of a given star rating. As a guide here are some suggested maximum storage times at -18°C for a variety of foods."
Feb 12, 2015 | Freezers
Liebherr comfort no frost not working
Have you tried cleaning the condenser coil. They are located at the bottom of the unit and have a fan blowing them. As clean as possible is very important to operation. Let us know about this step. Roger
Apr 18, 2014 | Liebherr Freezers
Apr 06, 2010 | Freezers
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Cannot reset the temperature on my freezer
What is the manufacturer of your freezer?
Jun 26, 2017 | Freezers
Temperature
Recommended temp for a freezer is -17C. That's MINUS 17 degrees Celcius.
Usually the higher the number the colder the temperature.
Oct 21, 2008 | Freezers
Freezers Logo
173 people viewed this question
Top Liebherr Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
