Question about Cycling
MERIDIAN TRIKE AXEL BEARING REPLACEMENT - Cycling
Posted by JOEL on
5 Related Answers
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Wheel bearing & drive axel replacement
lift the car support on jack stands remove the wheels remove the brake systems remove the wheel hub locking nut and then remove the strut (this must be compressed or it will hurt you)
remove the axles then when that is complete you need to have the wheel bearings knocked out of the brake hub or removed from the strut assembly and then a new pair reseated, or bolted on then you can assemble in reverse, if you are not mechanically inclined I would recommend a mechanic to do this.
Posted on Apr 07, 2009
Anonymous
  • 5 Answers
SOURCE: i eed to replace both rear rims for my 26
If your hubs are good, a good bike shop should be able to rebuild the wheels with new rims and spokes. This probably will cost more than a similar sized wheel for a 2 wheel bike.
Posted on Nov 03, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: schwinn meridian sprocket change
Local bike shop may have a way to find one and install it for you.
Posted on Jan 24, 2010
Anonymous
SOURCE: HI, WHERE CAN I BUY
Call Schwinn at 800 626 2811. They may send them to you for free.
Posted on Jan 31, 2011
Coachphil
Coachphil
  • 347 Answers
SOURCE: I need instructions for the
This comes up frequently. In my tips and tricks page is a link to the www.schwinn.com instruction manual download page. But they are most likely the same instructions you have already got. There are no other specific instructions for building.
So what is the best method of assembly? Not much beyond taking the project to your local bike shop and having them assemble it, Fees vary on this but it is the most effective method to make sure the bike/ trike is assembled correctly and safe to operate. Or you can find a friend that has some mechanical knowledge and maybe even owns one and can help.
Poor instructions are the norm, sorry. If you get the majority of the bike together you can post specific questions along the way and the community may be able to help solve that specific issue.
Posted on Apr 06, 2011
How do i replace rear wheel bearings on a schwinn meridian trike?
Your trike probably has cartridge bearings. If so they are a press fit, and need to be pushed out, and then replaced with a bearing that is exactly the same size (type will be printed on the bearing face). It's important to push the new bearing in carefully.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jul 25, 2017 | Schwinn Cycling
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
How do I correct the clanking noise in the rear of my Schwinn 24" Meridain Tricycle?
It could be that the chain needs tensioned, or if it is a coaster brake, the hub may need serviced. The noise could be coming from anywhere and your best bet is to have a qualified mechanic look at it.
Oct 31, 2014 | Schwinn S4025 Meridian 24" Single Speed...
Where can I find instructions on replacing a back axle of the Schwinn Meridian adult three wheel trike
This is a difficult operation, you can try a video from Utube. But the best solution is take your trike to the local bike shop.
Oct 17, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Where can i order a 26 inch rim for my schwinn meridian tricycle, since it's badly wobbling from 6 broken spokes?
I just put my Maridian together and two days later hit a small pothole on the left rear doing about 15mph so I called Schwinn and they replaced the wheel with no hassle. They have mnfg standards and a lifetime warranty...
Apr 24, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Need new rear brakes on 3wheel trike how to?
The trike uses a band brake, refer pages 25 and 26 of the user manual http://www.schwinnbikes.com/media/uploads/blog/files/Schwinn-Meridian-Manual_Mar2011.pdf The Schwinn dealer should have a replacement in stock or be able to order one in for you. You may also be able to purchase one from eBay if you measure what size you need.
Mar 21, 2013 | Schwinn Meridian Adult 26-Inch 3-Wheel...
I eed to replace both rear rims for my 26" schwinn meridian trike. I have had no luck finding source. Also, i would like to find an inexpensive battery powered drive for the sae trike
Oct 24, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cycling Logo
167 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
