Sewing Machines Logo
Question about PfaFF Sewing Machines
How do I thread a Pfaff grand quilter hobby 1200
Top thread keeps breaking . I have cleaned machine etc
Posted by Denise Gaizauskas on
4 Related Answers
Anonymous
SOURCE: can not get thread tension on hobby 1200 grand
Adjusted the dial to the right until the stitches we better.
Posted on Dec 27, 2009
Anonymous
  • 1456 Answers
SOURCE: I have a Pfaff grand Quilter and my top thread is
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Posted on Jul 15, 2011
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
Posted on Dec 10, 2015
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: Pfaff grand quilter 1200 - how do I adjust the timing of the machine? Thanks, mike and mum!
Search for "sewing machine timing."
Posted on Aug 30, 2017
How do I thread hobby grand quilter 1200
The Hobby 1200 is a Pfaff sewing machine that they call the Grand Quilter. First raise the presser foot and make sure that the needle is at the highest position (press the needle up/down button twice with the machine on). Then turn off the machine and unplug it for the maximum safety. For the top thread, place a spool on the spool pin and guide the thread through one of the two thread guides on the thread guide bar. The thread starts from behind the guide. (The post holding the guide bar is next to the spool pin.) As with most sewing machines, you will work from right to left and lead the thread down then up before going down to the needle. Bring the thread to the next thread guide (in front of the bobbin winding pin) and pass it through one of the holes from the back. Wrap the thread to the back of the guide and then through another of the holes. If the thread tension is very loose, try going through all three holes. Bring the thread down between the pre-tension discs going counter-clockwise.
Hold the thread in both hands and guide it around down and around the tension dial from right to left. Bring the thread up to get it between the tension discs and behind the tail of the check spring. Bring the thread back down over the loop of the check spring then under the thread guide that looks like an upside down L with a curve in it. Bring the thread up and through the next thread guide. (This guide is horizontal and just above the previous guide and one side ends near the center of the tension dial.)
Bring the thread up and pass it through the eye in the thread take-up lever and then back down through the horizontal thread guide above. Slip the thread into the thread guide and then down to the needle bar thread guide. Thread the needle from front to back. The thread should be along the groove in the needle.
You can find the manual at Pfaff's Machine Update page: http://www.pfaff.com/en-US/Support-and-Updates/Support . Search for the model and then you'll get to the product page: http://www.pfaff.com/en-US/Support/3336 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/GrandQuilter-manual-EN.pdf . The threading section starts on page 21 (page 23 of the PDF). The manual has good pictures that are better than my attempts to describe the guides.
I hope this helps.
2helpful
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
2helpful
Why does My thread on my pfaff hobby 1200 grand quilter does not break, it seems to just come out of the needle...why. I leave about 4" on it. It doesn't pick up the bobbin thread either why?
Pull through more thread--probably 6" would work. Also, try holding the thread tails lightly with your left hand while you take the first stitch.
Not picking up the bobbin thread? Try a brand new needle. If that doesn't work, then the machine probably has a timing issue. Search the internet for "sewing machine timing" OR take it for service.
1helpful
How to thread a pfaff 1200 grand quilter sewing machine
contact Pfaff website about a manual or try youtube for a video
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
