Question about Refrigerators
Hi.. i have water in the bottom of my Kitchen Aid fridge,,, i have to remove it about once amonth.. what is wrong,, how can i fix this,, thanks for your understanding,,thomas
Posted by Thomas Sekersky on
Lee Hutchinson
    Habit-Forming:
    New Friend:
  • 89 Answers
Its defrosting and the drain is probably plugged keep door closed and unplug for a few hours your problem should clear up, there might be some water in the fridge and on the floor no need to panic if this does not work you might have to get a repair man to clean out the drain
Posted on Aug 27, 2019
brian williams
    Genius:
  • 1,864 Answers
Clogged drain tube
5 Related Answers
Mark Egan
  • 1214 Answers
SOURCE: Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Posted on Jan 21, 2009
fortross
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
Anonymous
  • 68 Answers
SOURCE: kitchen aid refrigerator water dispenser does not
could be a few things. fist, when you call for water, listen for a very faint "hum" noise, if you do hear that, it is either the solonoid on the valve, or the reserve tank in the frige froze. easy way to check. pull the frige out and un-plug from power. on the back of the unit is a cover on the bottom, remove cover. the valve is on the far right as your looking at it. it has 2 solonoids on it. there are two plastic water lines on the bottom of the valve, i believe the one on the left is for ice maker, and the right one goes to door dispenser. remove the water line going to the door dispenser and put a cup under the valve. plug in frige and call for water at the door for couple seconds, check to see if water came out of valve into cup in back. if it did, the valve is ok, if no water, replace valve. they run about $50. if you didnt hear the hum i talked about, and the valve is ok, let me know and i can walk you through checking and replacing the switch in the dispenser. good luck, shane
Posted on Aug 24, 2009
Testimonial: "I will do that, but wont be until later, thank you for the info and if it does not work, I will let you know so you can advise me more. Thanks Shane"
Anonymous
SOURCE: water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Posted on Jan 01, 2010
Sean Miller
  • 116 Answers
SOURCE: My Kitchen Aid clothes washer is leaking water
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Posted on Mar 29, 2011
Why did my ice maker in th efridge stop making ice what can ido
if its not feeding water too
remove the filter inside door bottom right , try water again.
Roll the fridge out look for the cutoff valve on the water supply an turn off water disconnect an drain or back flush or run some air or water in reverse , clean it out , test the water valve for water an expect some spraying of waters so unplug it all an git help.
Jan 05, 2015 | Refrigerators
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
KITCHEN AID SIDE BY SIDE KSRP25FSMS01 We first niticed the freezer and fridge not being cold enough, then it stopped making ice. The freezer would not freeze things but still felt cold. I cleaned the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 18, 2010 | KitchenAid Refrigerators
My kitchen aid refrigerator is not cooling like it use to, the freezer side is ice cold but the fridge side is almost at room temp, i have a feeling its the thingy in between the freezer and fridge at the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | KitchenAid KSRS25IL Side by Side...
Water dispenser suddenly stop working
We have a Kitchen Aid that did the same thing. It could be that the reservoir tank is frozen or it could be that the line is frozen. We called Kitchen Aid, our fridge is under warranty, and they installed a freez kit over the tank and that solved the problem. The tank might be behind the vegetable trays on your fridge. What brand do you have?
Mar 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
Jan 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
No ice production
Chances are the fill valve at the bottom back of the refrigerator is clogged or failed. This valve opens to allow water to fill into the icemaker.
It could also be that the fill switch in the icemaker has failed, or depending on type of icemaker, the ice level bar is flipped up, or the mold heater sensor has failed.
Please provide the refrigerator P/N for more information.
Jan 15, 2009 | KitchenAid Refrigerators
Frost on bottom of freezer inside refrigerator section, leaking
Hi!!! You have a plugged drain line in your evaporator..For a quick fix just turn off your frig for 24 hours and set your temp control at the factory setting listed on the frig and you will be finw trust me..Good luck..
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
