Question about Lands Phones
NEED TO CANCEL RESIDENTIAL LINE - Lands Phones
Posted by JAN ABRAHAM AUGUSTYN on
I need a residential phone book
Hello, Audre -
If you reside in the USA, you may wish to use: https://www.whitepages.com/
The challenge these days is that if a person only has a cell phone and no residential land line phone, it is not easy to find any free directory which provides the cell phone number for an individual. However, often printed city or city / county directories, which are published by companies owned by credit clearinghouses, will provide the credit billing addresses (often the residential address) and the telephone number for residents in a particular city or county in the USA. Generally, a public library will hold printed copies of city and city / county directories for locations in the library area of service.
Polk is one of the publishers of city and city / county directories in the USA:
https://www.polkcitydirectories.com/
Best wishes.
Sep 02, 2018 | Cell Phones
What size of copper tube use in liquid line and suction line in split air-conditioner?
depends on the tonnage & mfg. i have seen 1/4 liquid line to 5/8 inch & on suction 3/4 to 1 1/8 on residential units.
Aug 07, 2015 | Heating & Cooling
How do I find residential phone numbers
go on line --go google and type in --white pages for the area you want to ring
Jan 11, 2015 | Cell Phones
T7316 phone does not cancel call forwarding
#73 is a a feature you use on a telephone line to cancel call forwarding (cfw) of an outside call (some codes may differ). You need to have the dial tone of that outside line to cancel the cfw. to cancel the cfw of a norstar set (internal calls to extension) just press the cfw key or press 'feature #4'
Apr 15, 2014 | NorStar T7316E Corded Phone
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
The ideal 61-165 is listed to 240v. Is that L-L, or L-N as in European voltages?
In the United States Line to Line (L-L) for residential services is 240 volts at 60 Hertz (Hz) US Line to Neutral (L-N) is 120 volts. United Kingdom residential services L-N is 240 volts at 50 Hz. The Ideal 61-165 is intended to be used in the US.
Apr 30, 2011 | Ideal 61-165 Arcfault 165
How to wire a ps3
Hey allisc,
In order to connect your PS3 to the internet, you will need one of two things: a hard-wired connection, or a wireless residential gateway. Please keep in mind that your options may be limited by the PS3 model that you own, and that a wireless connection is not possible with some models.
The most straight-forward type of connection you can make is a hard-wired connection - simply use an Ethernet cable to connect your PS3 directly to your residential gateway. By establishing a direct connection, the PS3 should not need any additional information in order to access the internet. The trade-off for the simplicity of a hard-wired connection is that the number of places you can physically place the PS3 itself are limited by the length of Ethernet cable used.
Should you wish to use a wireless connection instead, you will need to own a 40GB, 60GB or 80GB PS3 and a wireless residential gateway. The 20GB model unfortunately does not support wireless capabilities at this time. Please keep in mind that connecting wirelessly can often prove to be more complex than using a direct connection, as you not only need the name of your router, but information on any established security settings as well.
The most common security settings that may be in place are Wi-Fi Protected Access (WPA) keys and Media Access Control (MAC) filters. MAC filters are essentially a series of "blacklists" and "whitelists" that restrict network access based on hardware configuration. WPA keys however, are "passwords" that allow your computer or video game console to decipher a code used by residential gateways which prevent unauthorized users from using your personal internet connection.
Both forms of security may typically be set and changed by accessing the gateway directly through its default website. This default website can vary depending on the brand of the device, but many companies may use one of the two default addresses I've provided below:
192.168.0.1
or
192.168.1.1
Please keep in mind that in order to access the gateway's control panel you will need to have both the admin user name and password!
Once you have gotten access to your residential gateway's control panel, you should then be able to add the MAC address of your PS3 to the gateway’s MAC filters, as well as copy down any WPA key used by the network so that you may later enter it into your PS3's memory.
If you are still not sure how to proceed or do not feel comfortable doing any of this, I would strongly suggest contacting either your internet service provider (ISP) or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Lands Phones Logo
124 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
