Question about Samsung Televison & Video
Good day... I have a 40" Samsung LED TV that is malfunctioning. It comes on and if all of the lights are off and the room is completely dark, I can see what is on the screen, rather clearly. I have checked all three (main) boards in the set and none show any obvious signs of failure. The power board has a slight warp in it but nothing else seems to be wrong with it. I have read that with issues similar to mine, the T-Con board is shot, however, while I can hold my own when it comes to replacing parts in electronics, I am not a pro. Without actually looking at the set, is there anything I can tell you or do for you that would identify the issue? Thanks in advance for your time!
Posted by Jon Tyre on
Ed Cole
    Habit-Forming:
    New Friend:
  • 123 Answers
Sounds like the backlight led inverter board is bad. Easy to replace. Google for replacement board.
Posted on Sep 02, 2019
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Same old red convergence issue
they wont show any signs of being bad if you cant adjust the convergence the ICs and possibly a few of the convergence resistors will need replacement. You can get new ICs and resistors at the following link and they come with free instaltion instructions.
http://servicemanuals.vstore.ca/
Posted on Jun 21, 2008
Anonymous
SOURCE: power light comes on and clicking is heard but no
your problem is more a defective y board with y buffer boards one of them is short
Posted on Oct 26, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: TV WONT SWITCH ON LE26A456C2D standby light blinks
Please read my giude then you may understand more as to what it takes to make the TV functions.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Mar 06, 2011
Tony
  • 127 Answers
SOURCE: Samsung TV Model LA40A650A1M back light intermittently strobeing
You can't see if a cap is good or bad jus looking at them they have to be measured>They loose their capacitance because they dry overtime.
I do sugest that you replace you power supply module or replace all caps.Possibily you may have a broken line in the PCB
Posted on Nov 01, 2012
gopakumarg43
  • 76416 Answers
SOURCE: I have a PUREVIEW 40" LCD TV Model# PV40LD400. I have Power but no picture or sound. I replaced the Backlight Inverter and the power board but the TV is doing the same thing. It will power on and the
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 22, 2014
Dark picture on samsung led tv
Please replace all of the LED back lights strips.
Apr 06, 2018 | Samsung Televison & Video
Samsung TV backlight is very dim on LN40B530P7N Television
Check if the sensor of the ambient light in the room is dirty (bottom of TV). If so, the TV thinks its playing in a dark room and so sets the screen to dim.
If that doesn't improve things, turn a flashlight on the sensor to fool it into thinking its a brighter room.
Aug 26, 2017 | Samsung Computers & Internet
MY MAGANAVOX 32 INCH LED TV WONT TURN FULLY ON-THERE IS A RED LIGHT THAT IS ON BUT THATS IT-THE SCREEN IS BLACK
  1. open back panel (note do not touch any of the Boards and components on them unless you have good knowledge of ESD).
  2. connect TV to power and turn it on in a very dark room. you will now find out what works and what does not.
    1. if you can see white lights on the back of the TV then Back-light is working and visa versa
    2. plug your cable device in with the correct input selected. either AV1/HDMI1 will usually be top of the list now listen for sound
    3. Now while in the dark use a torch or your eyes if you are not in the dark, option 1 comes highly recommended. Look and see if you cant see a feint image of the menu
  1. Now your troubleshooting is completed its time to interpret your results.
    • If 2&3 are a yes and 1 is a no then replace LED Driver. Still persists then the LED strip/LED's are damaged
    • If 1&2 are a yes start by replacing t con board. Still persists replace the main board
    • if the only yes is 1 then you definitely want to change the mainboard
    • Now guess if nothing is on, what is probably the cause?
    There is however a much shorter procedure and if you are a logical thinker you will not only learn exactly how LED TV's operate but also how to shorten this solution OR call a guy/girl that has the magic touch
May 02, 2017 | Televison & Video
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
Televison & Video Logo
81 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
