Question about Sharp Televison & Video
I have 2 PN-LE801 Sharp TVs, one has a green line on right side and the other has a black cloud on right side. What part(s) are needed to resolve these two issues.
Posted by Kirk Berube on
5 Related Answers
Anonymous
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
Anonymous
  • 214 Answers
SOURCE: black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Posted on Jun 19, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
Anonymous
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Posted on Sep 28, 2008
Anonymous
SOURCE: Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Posted on Apr 02, 2009
Green lines in black areas
sorry to say your LCD panel is failing they are expensive , i hope your under warranty
Nov 23, 2009 | Televison & Video
Black line on copies produced
Take a look at your drum. If there's a green tab on the exterior, move that all the way to the left. That should get rid of the black line.
Jul 16, 2009 | Brother MFC-7440N Laser Printer
3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Jan 11, 2009 | Clarion XA-311 Cassette Player
Sharp aquos vertical black line
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Nov 15, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Big Black Ink Line in all copies
Lift up a lid and clean the tiny scanner glass. One black dot will cause that effect to happen when using the document feeder. If the glass is clean, open the door on the right side and look at the green drum for lines. If you see any lines on the drum, then it's time for it to be replaced.
Sep 22, 2008 | Sharp AL 1631 Copier
Green vertical line on the right side of screen
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green Cloud show close to mid lower left center on most black screen
you will need the optical unit cleaned, if that does not resolve then the optic unit needs replacing
Jun 18, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Open Questions:
Televison & Video Logo
50 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
