Brother MFC-6490 - Accidentally put magenta ink cartridge in black cartridge slot. Now that we've replaced it correctly, still printing magenta instead of black.
Already tried cleaning print heads & printing a lot of pages to try & get any remaining ink out of well.
My brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
You must have to do the cleaning process many times as necessary until it prints correctly.
Since the pipes still have magenta ink, it will have to drain all the magenta ink.
Press Ink Management, then select Cleaning Black. At the end print the quality test page.
Do the procedure until it prints correctly.
It will eventually clear itself !
Most of the Brother MFCs use ink Tanks NOT ink cartridges, as the MFCs have a separte print head - ink cartridges include a print head which get thrown out with the rest of the cartridge when replaced. This is why Brother ink replacements are so cheap compared to "normal" inkjet printers.
It may seem like it's taking a long time, but there is quite a lot of ink in the pipes from the ink tanks to the print head.
POWER PURGE!!
a.
Press INK.
b.
Press the UP OR DOWN ARROW key to select Test Print.
c.
Press OK.
d.
Use the UP OR DOWN ARROW key to select Print Quality.
e.
Press OK.
f.
Press COLOR START
The
machine will generate the Print Quality Check Sheet.
2.
The LCD will ask "IS QUALITY OK? 1. YES 2.
NO"
a.
Press STOP/EXIT to return to the "Date and Time" display.
3.
Evaluate the Print Quality Check Sheet.
On
the Print Quality Check Sheet each of the four colors is represented by a
slanted square pattern made up of 96 individual blocks. The colors should appear
in the following order from left to right: Black - Yellow - Cyan -
Magenta.
NOTE: Cyan
is the light blue color and magenta is the pinkish color.
a. If
the colors on the Print Quality Check Sheet do not match the sequence listed
above then the ink cartridges are most likely installed in the wrong order.
Continue to STEP 4 to resolve this.
4.
Open the Ink Refill cover.
5.
Open the cartridge covers of the colors that do not appear in the correct
order.
6.
Remove the cartridges and reinstall them in the correct slots. On Brother
Genuine Cartridges the color of the label will match the color of the cartridge
cover.
7.
Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink
supply tubes with the correct color. One or more of the ink cartridges may run
empty during this process. If they do, replace the empty cartridge with a
Brother Genuine Ink Cartridge before continuing the process.
a.
Press MENU - BLACK START - MENU. The LCD will display
Maintenance.
b.
Press 7-6, The LCD will display CLEANING ALL
c.
Press 6, the LCD will display eINIT__P ALL
d.
Press the RIGHT ARROW key until one of the colors that was installed
incorrectly is displayed. i.e. eINIT__P CYAN.
e.
Press the BLACK START Key.
8.
Print another Print Quality Check Sheet
a.
Press INK.
b.
c.
Press OK.
d.
e.
Press OK.
f.
Press COLOR START
9.
The machine will generate another Print Quality Check Sheet.
a. If
all four colors printed correctly the issue is resolved.
b. If
one or more of the colors are still not printing in the correct order repeat
STEPS 4 - 8.
