Dryers Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't heat up and doesn't shut off - Dryers
Anonymous
Level 3:
  • Master 430 Answers
  • Posted on Sep 13, 2009
Anonymous
Master
Level 3:
Answers
430
Questions
Helped
270989
Points
1149
You likely need to replace the element. test the dryer in auto and timed dry cycles. If the element is gone you will have no heat in either.
If the humidity sensor is shot or the dryer vent hose is clogged , the dryer will run forever and not dry or shut off.
Check for blockage first. then run a test cycles on both settings and post back
1helpful
Electric dryer wont heat
hi 1st check heater for breaks then go for stats
99 Jetta won't turn off when I remove the ignition key and the temperatur guage doesn't move but the fans come on?
Electrician has miswired the car or didn't properly repair the short. Very hard to know what he did wrong. Will he not fix it himself?
My heat doesn't work.
Check the coolant level...if it's low the heater core in the car won't make heat.
Does the fan work?
GL,
Td
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 • Dryers
1helpful
2answers
Microwave won't heat
Sounds like the magnetron has failed. :(
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
My ibm think pad a22m doesn't turn on . the fan isn't working have power but won't stay on
Chances are that if the fan isn't working then its over heating and shutting down. Check to make sure there is no dust or pet hair clogging it up. If there is then try and clean it out with compressed air. If there is no obstruction then the fan may have died on you. Only thing to do is look into getting a new fan or take it to a repair shop.
Best of luck
Top Dryers Experts
john h
