Whinning is loudest when 03 Impala is first started. Transmission fluid is fine and works well. I wanted to check the fluid level of power steering and cannot find stick, have 04 Impala manual that says location is rear of engine on passenger side. Not visible in 03 engine. Mileage is 103,500
How can i take of a power stering from impala 03
The power steering pump is more than likely either low of fluid or it is about to fail. You MUST check the fluid level. The pump is located on the passenger side rear of engine. You will see a round cap, remove it and check the level. It is there, so look until you find it.
Check top of power steering pump, remove cap read instructions on cap
One of the lines from the pump should lead you to the reservoir.
