Question about Coffee Makers & Espresso Machines
My Coffee machine is behaving very strange goes off as switch on ERROR 17 / JURA 5 kindly advise what should i do to work.
6ya staff
SOURCE:
Anonymous
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
Anonymous
SOURCE: My dispay on my jura E8 says error 5.
Has anyone found a place to service a Jura Capresso Impressa E9 in North Carolina?
Posted on Jan 05, 2010
Anonymous
  • 3 Answers
SOURCE: Our Jura coffee machine S9 model has error message
Hi, Printed below is the fault for Error 4:
STEAM: Temperature sensor notify “value above tolerance”
I hope this helps.
Alison, Uno Coffee Company
Posted on Feb 19, 2010
Anonymous
SOURCE: Jura z5 after filling system said coffee ready
Someone online sells a special screwdriver head used to open the Z5. With it, it's possible to take the machine apart, clean up the coffee ground dust that gums up the moving parts. You can giggle sensor switches that get stuck. The water lines will need decalcifying eventually, even if you use the the Clearyl water filter cartridges. If you're not up to taking machines apart, sell me your broken Z5: [email protected]
Posted on Jun 17, 2010
alicantecoli
Colin Stickland
  • 22485 Answers
SOURCE: My built in Gaggenau coffee
i think its telling you that either the water level is low or its not filling if on automatic fill ,
Posted on Oct 29, 2010
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
My jura j9 continues to show the error of "empty drip tray" I have cleaned the metal connectors in the back and cleaned and dried the back of the Machine. Please help
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really dirty!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!!
Nov 25, 2015 | Capresso Jura Impressa J9 One Touch...
Jura f70 error 8 solution
There is a Jura Error Guide that says:
  • Turn machine off, turn the main power switch off and unplug machine for at least one minute.
  • Turn machine on again. If the error message comes up again, try one more time.
Dec 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Pierre Laplante
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
