Question about Breville Coffee Makers & Espresso Machines
I have a Breville 800ESXL. The red light flashes but the unit does not heat up. Gets water thru the group head but is cold. worked fine one day and the next morning it didn't.
Posted by Dave Heger on
Tom Chichester
    Top Expert:
  • Breville Master
  • 57,312 Answers
The blinking red light probably is indicating heating element or control circuit failure.
Posted on Aug 26, 2019
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: FixmeBob Great help with Breville 800esxl
I had a similar problem, but no blinking light, only cold coffee. I tapped on the relay (black box on circuit board) and violá.  Red light, hot coffee, and happiness.  The machine did the same thing a couple of weeks after the "fix", and a good slap to the left side, and I was back in business.  My guess is that your switch is bad or sticking.  Good luck.
Posted on Apr 08, 2008
Anonymous
  • 29 Answers
SOURCE: Flashing red lights
try checking out this website it worked for me. www.epson.com/ipr
Posted on Jun 12, 2008
Anonymous
SOURCE: No water thru the group head
We were having the same problem and this worked for us, right from an insert that was included with the manual.
1. Fill tank with water
2. Remove the filter holder
3. open the steam tap
4. press the main switch and the coffee switch at the same time
5. close the steam tap as soon as water begins to flow
6. If after 30 sec. no water comes out repeat the operation.
7. when it starts, draw off 4 cups of water
This worked for us after we had about given up,
Posted on Jun 21, 2008
Anonymous
SOURCE: breville 800esxl won't extract coffee or steam milk.
is your machine new or is this a new problem? If you have had the machine for a while there is a possibility that your double wall filter is clog between the walls which would prevent the water from going through (this happens when your grind is too fine). If however the water does not go through when you do not have a filter in the basket than you have a diferent problem.
Posted on Jan 28, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Breville 800ESXL backwash????
Posted on Jun 20, 2009
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Doesn't heat the water Start...makes noise, the
the flashing heating light indicates that it isn't getting water. This could indicate that your pump has gone bad.
Oct 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville 800esxl,won't stop pumping even in standby.
1- Are you using distilled water? If yes then the machine cannot sense the water level in the boiler.
2- Where is the water that is being pumped going? If it is coming out the drain tray, then the solenoid for the group needs to be replaced.
If it is coming off the top of the boiler, Then the level probe is calling for water, in which case you will have to remove probe and clean with a wire brush.
May 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Temperature adjustment?
the rear temp sensor is in charge of the brew temp. To increase the temp, lift sensor and clean out the thermal paste. To further increase, insert some fine metal mesh between sensor and boiler. The front senser is for emergency (overheat) cut off. Don't tamper! Brought to you by Jim Vonkas
Mar 16, 2008 | Breville Die Cast 800ESXL Espresso Machine
Feb 06, 2008 | Breville Die Cast 800ESXL Espresso Machine
Makes espresso, coffee, water, but will not steam
The pump has gone bad - through use. This is a common problem, and has to do with the "seals" that are in the pump. Since the pump generates high pressure and heat, over time, the seals will fail, and will be unable to generate enough pressure and heat to create steam. The only remedy is to have the pump replaced through the Breville Out of Warranty repair centers.
http://www.brevilleusa.com/support/service-centers.pdf
Dec 11, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
196 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
superdad1976
Colin Stickland
Colin Stickland
Charles Tidwell
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
