I have an Alba tv it’s in standby mode blue light on when I try to turn it on it licks between orange on and blue standby mode and eventually turn on after about half and hour only just started happening any suggestions please?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If it turns off after a while that's a transistor going hot.
You need a technician to test it for you. If you want to do it yourself
let me know. Good luck.
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
My tv just over a year old
Alba LCD32947HD - PSU - 17PW25-4 - 250111 V1 - 23012666
gets no power on and not even a light in front after I plug to the mains. Checked and power goes to the psu , main Av and the Inverter. Can somebody help? Could that be the remote control. Please help. Thank you in advance. Harry.
just had the same problem blue light flashing no sreen what i did was press the standby button on the side of tv very fast about twenty times and it came on but now have a little black shadow on the left hand side
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
