Question about The Computers & Internet
Purchased a BWA19AV910 splitter today and when I hooked up two additional monitors to my laptop I am getting the same display on both. its not seeing two different monitors.
Posted by Norm Hart on
Vernon Taylor
  • The Master
  • 6,582 Answers
I don't know much about these things but I am guessing there is only one signal to split so regardless of how many times it is split, all the images will be duplicates of the original signal.
I seem to remember something from the dim and distant past - Windows does provide an option to work with two monitors but more than that I can't say. I think I saw it while skimming a manual...
Google search produced results below...
https://www.google.com/search?q=using+two+monitors&rlz=1C1CAFB_enGB673GB676&oq=using+two&aqs=chrome.1.69i57j0l5.11962j0j8&sourceid=chrome&ie=UTF-8
Posted on Aug 25, 2019
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Monitor works at Startup, then goes black
yes you can fix this problem go in to start menu then control panel then double click display, then screen resulution and add the secondary screen, bc windows doesn't add the screen automaticlly you have to do it this way
Posted on Dec 15, 2007
alvinbga
Alvin Barnabas
  • 130 Answers
SOURCE: Monitor Splitter
If it works it will only display the same image. There will be a voltage drop, which may cause problems.Which piece of hardware has the dual monitor setting?
Posted on Jun 20, 2008
Anonymous
  • 366 Answers
SOURCE: Laptop doesn't display when booting up
Be sure to be on AC and have battery recharging.
Then find on your keyboard the key used to circle through active display, it's usually having a screen icon on same color than FN (function) key.
Use both to change your active display: Main > external > both pause between changes, system needs time for reset.
Posted on Jan 24, 2009
micromend
George Brown
  • 748 Answers
SOURCE: cant extend workspace
The splitter you bought allows you to split one video signal into two. For example, a teacher using a computer to teach a class. She has one computer, one monitor she can see and then the splitter allows the students to see what she sees. To display independent screens you'll need to add another card to your system. Microsoft Help and Support lays out how to do this with Win 2000. No splitter involved.
Posted on Apr 10, 2009
Anonymous
  • 585 Answers
SOURCE: Monitor displays for less than second, then goes black.
If that model has no external power supply then the supply is internal and some capacitors have failed. It's a fairly common problem with that type of monitor. The capacitors are cheap, and not too difficult to desolder and replace. The hardest part sometimes is getting the darned thing open.
Hope this helps.
This is also a test, I have been having issues getting notices of replies through e-mail. Your input therefore is desirable.
Thank you.
Posted on Jul 16, 2009
I have a gigaware 26-1264 splitter that I hooked up to my laptop and the sound is only coming from my laptop - what did I do wrong? I can not find the manual or instructions to the splitter.
This product does not change your audio settings. It only replicates your screen onto another display. Primary uses are for presentations. i.e. to show an image on a monitor and also on a projector.
Sep 24, 2011 | Audio Players & Recorders
I have 2 identical Dell monitors on vga splitter plugged into port on laptop running Win 7. The NVIDIA control panel will only recognize the 2 Dell monitors as 1 display + 1 laptop display. How can I set...
you will have to change the settings in the control panel to an extended desktop once you have this lead connected click start control panel display change display settings you should a no 1 and a no 2 with detect and identify keep an eye on the television screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended tesktop always click apply after making any changes
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers hope this helps
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
Apr 11, 2011 | Impact Acoustics 2-Port DVI-D VGA Splitter...
I would like to use my new flat screen as a monitor for my laptop presario v2000. can you suggest a method of doing so?
You can either purchase a laptop dock (if available), I'd check the HPs site for information. You can also hook up monitors to almost all laptops using the VGA connection on the side of the laptop. An additional key combination may be required to display to the monitor. It's usually Fn + F2 or Fn + F4
Feb 24, 2011 | HP Compaq Presario V2000 Notebook
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
How do you hook up an additional set of speakers to this monitor so that I have four speakers working?
You'd need to get a 3.5mm stereo audio jack splitter (aka "headphone jack splitter").
It'll look something like the pictures below.
You should be able to purchase one for a few dollars pretty much anywhere you buy electronics or audio equipment (Radio Shack, Best Buy, etc.).
Once you have that, make sure both your computer and your monitor are turned off.
-Then, unplug the audio cord (that goes from your monitor to your computer) from your computer (you can leave it plugged into the monitor).
-Plug the splitter into your computer where the cord was previously plugged in.
-Next, plug the cord into one of the open jacks on the splitter.
-Plug the audio cable for your *second* set of speakers into the other jack on the splitter.
You should be able to turn on all the devices and have audio coming from all the speakers now.
Let us know if you have more questions!
May 31, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Hooking up 2 additional monitors..
you can try to use a y splitter. the problem with that is the receiver will not give you enough "power" to power up the headrest. You will probably lose picture quality. There are amplifiers that can be purchased that will have extra outputs for video, this would be your best bet. It will give you great picture quality.
May 18, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does...
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Jan 07, 2010 | Computers & Internet
How to set up multiple external monitors on a laptop
Since you only have one external monitor port, you need to use a video spillter, this will allow you to connect two or more external monitors.
NOTE: This video splitter will only give you duplicated displays. Please check the link below:
http://www.kvm-switches-online.com/video-splitters.html
Thank you!
Dec 29, 2009 | Toshiba Qosmio F45-AV412 Notebook
Cant extend workspace
Apr 10, 2009 | Computers & Internet
Monitor Splitter
Jun 18, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
49 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
