Question about Refrigerators
Can you reset mbf2256keb fridge?
The fridge was on its side for 5 days , left standing for 7 days but it does not cool or freeze
Posted by Jim White on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 55,695 Answers
Leaving it on its side for five days finished it off.
Posted on Aug 26, 2019
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Posted on Dec 08, 2007
robert samples
  • 1314 Answers
SOURCE: side by side quit cooling - freezer & fridge
look on the compressor if there is a white relay box on it take it loose and shake it if it rattles and black stuff falls out go to the appliance parts store and tell them you want a three in one relay follow the instructions its easy and you will be fixed
Posted on Feb 11, 2008
Anonymous
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Freezer is only cold not freezing, fridge is cool not cold
You will need to remove the rear panel in the back of the freezer compartment. If Frozen over defrost with a hair dryer. At the bottom you will see a defrost heater WR51X10101 Defrost Heater it has glass around the element inside and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Posted on Aug 27, 2009
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Frigidaire side by side. Probably about 7 or 8 years old. It cools and freezes fine. Recently it has been making a loud buzz for about 5 or 6 seconds at a time. It dosent do it all the time but...
Hi; Cory this sounds like a water solenoid letting in water to the ice machine. Sometimes the solenoid can loosen itself from the water valve. Pull the fridge. forward GENTLY.We dont know how much water line was left in the back of unit. Cory unplug fridge. Then remove the screws on the lower cover. Usually a 1/4 or 5/16 nut driver will do nicely. Then just follow water line to the water solenoid valve check for anything weird...Worst case scenerio the internal parts are starting to wear a bit.
If You find alot of dust please remove with vacume clnr.
This will help cooling operation and Your fridge will love You long time. let me know...alpharome416
Feb 23, 2010 | Frigidaire FRS26R4A Side by Side...
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
