I have an HB flat screen,but am struggling to open using RM-L812.pliz help
Posted by austin on
1 Related Answer
Anonymous
SOURCE: pliz help me my PHILIPS
The problem is that the tray is moved by a belt, this belt is the problem, it's located under the tray, replace the belt and your problem is solved.
Posted on Jan 28, 2011
My sanyo cm21ms22 has developed a problem on the screen, where its cutting pictures by half and not filling the screen. Pliz help.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 27, 2016 | Sanyo Televison & Video
Pliz help guyz i need the model number of of ic used in elegance electronic keyboard JC-918 lcd display
The number is on top of the ic. Open unit up and read the info off of it.
Mar 10, 2016 | Televison & Video
I forgot nokia asha rm 987 security code?
default one is 12345
if u hav set your own code
1. use nokia software updater to re-install ur software
http://nds2.fds-fire.nokia.com/fds_fire/1405/1213/7361995544/NokiaSoftwareUpdaterForRetail_4.2.1.exe
2.contact nokia care
Nov 25, 2014 | Nokia Cell Phones
Hie my name is Carjo n l live in Zim , l hv a Telefunken Netpad 7A3GEA wth a cracked or smashed screen .Where can l buy or get another 7 " inch" screen .Pliz help
It will be best to buy an other one instead of trying to repair this unit. The component you specified here will be very difficult to get by open electronic spare part market.
Jun 10, 2013 | Televison & Video
CAN YOU PLIZ HELP ME FIX MY TV
Press the AV button on the remote control. If it do not help you, make it a hard reset.
May 28, 2013 | Universal 40-42 Inch Flat Screen Panel...
Bios page won't function. I'm trying to Setup with F2 but none of the functions work. I'm using an EE pc 1005 HB.
Hello wmalvinx.
in the manual they say press F2 twice.
first press will show then post screen
sec. press open the bios.
mfg Gue
Feb 26, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I cannot load my farmville since last night but i can open my facebook and accept gifts. but cannot play...my crops will wither help me pliz...pliz
Here are given a few simple steps which will help you if Facebook games crash in your PC:
Repair Active-X, Flash and Other Registry Error using registry cleaner reginout
check Flash Player Compatibility
Updating the Sound Drivers
Dec 04, 2010 | Microsoft Internet Explorer 8
Pliz help me my PHILIPS DVDplayer recorder the dvd tray doesnt open i really dnt know why i used this product after 1 year before one year it worked wonderfully and now the dvd tray is nt opening pliz...
Switch off the unit, remove the cord. Ope the top cover, you will see the loading assembly, just beneath the assembly tou can find a threaded shaft on which OPU is mounted, try to turn the shaft, OPU will start sliding and it will open a small window by which you can see one black belt, just skid this belt so that it turn a while, tray will start coming gently, now hole the tray from outside and gently pull it out, DO NOT apply any lubricant, You shoul dchange the belt now.
Oct 05, 2010 | Philips DVDR520H DVD Player/HDD
NOKIA 6300 SECURITY CODE LOCK!
we cant fix it here, but go to service center and they will do it like this , put the cable in u'r fone , run the soft, reset your code.. gud luck..
Apr 19, 2008 | Nokia 6300 Cellular Phone
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
