Question about Cycling
How do I charge adi2 battery on a focus Paralane 2 9.8 ebike
Posted by David Jaff on
Can a hub motor on ebike be started with battery charger ?
unlikely
starters draw more amps than most battery chargers can supply so it will blow the charger fuse
have the battery checked and if faulty -replace , then you can charge the battery while it is still connected in the bike
Jun 10, 2018 | Cars & Trucks
Ford focus 1.8 tdci 2003 battery going flat after standing 2 days
You ether have a bad batter that won't hold a charge or you have something staying on. or your alternator isn't fully charging your battery.
Feb 27, 2015 | 2003 Ford Focus
Ebike in need more power adding
You can add two 12 V 12AH battery in series. The total power now would be 720 W and your motor can bear it.
Oct 19, 2012 | Prodeco Technologies 2012 Stride R 36v...
Ford focus 2003 will not hold a charge/new battery
Checking the battery terminals are tight a grease free is an easy test.
The alternator needs checking to make sure it is charging the battery when the car is in use otherwise the battery will just deplete. :)
Jul 03, 2012 | 2003 Ford Focus
How to replace brakes on my ebike
It's unclear what the problems is. Worn pads? Piece o' cake. Broken brake assembly?
Web search "replace brakes on ebike" or, if it's just a regular bike with a motor on it web search "replace brakes on bike". Lots of videos.
There are ebike forums, too.
Aug 10, 2011 | Cycling
I have two protanium batteries for my Campus Electric bike. Neither of them will charge. BP-L2410EH2 and BP-L2410EB are the numbers on the back of the batteries. I bought my bike from a bike shop in...
Well, I think the answer is in the question...
Either the charger is bad, or the batteries are. Have someone qualified check the charger voltage.
Replace whichever is bad.
May 22, 2011 | Schwinn Cycling
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
Battery light comes on for 1-2 minutes than goes off. Just put new battery in car and still is coming on for 1-2 minutes. 2002 Ford Focus
hi, might wanna check the atternator ,check the belt make sure it still on .over time they get old and loose. if still on you could do a test, while the car is on diconnect the ground wire off, if the car stays on the atternator is good. if the cars turns off , you got a bad att. thanks hope been some help
Sep 28, 2010 | 2000 Ford Focus
I just bought a wuxing ebike and i cant get it started the battery is fully changed i turn the key and nothing
the problem might be with the connecting wires or the gear fuse of the switch might have melted down just get them checked. u cant do it all by yourself
Mar 10, 2010 | Electric Bicycle Motor, Bike,electric...
Cycling Logo
161 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
