Question about Salter Health & Beauty
When I try to weigh something on my Salter kitchen scale, after the 88888 shows, then an "E" comes up, so that I can't weigh anything. What should I do?
Posted by Anne Fox on
Garry King
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Change the battery
Posted on Sep 16, 2019
5 Related Answers
Anonymous
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
Anonymous
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
Anonymous
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
Anonymous
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
Anonymous
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
https://www.pricescompare.co.uk/q&a/ee-showing-on-screen.html
Sep 12, 2014 | Salter 2001 electronic kitchen scale
How to reset as scales are not weighing properly and new batteries have been inserted
These scales cannot be calibrated so i'm afraid that it's time for a new set. I think they were first manufactured in 2002 and they have a 10 year guarantee which meas you are out of luck. If you are in the UK, this site is a good place to start looking for another set of All Kitchen Scales
Jan 23, 2014 | Taylor Salter 1010 Stainless Steel...
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
155 people viewed this question
Top Salter Health & Beauty Experts
Marvin
Marvin
Vernon Taylor
Chris Benedict
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
