Do I need a converter box to watch TV or just an antenna
Posted by Camille Bridges on
William Norris
    Scholar:
  • 107 Answers
It depends on the tv itself, all newer TVs will just need an antenna but if the tv does not have the newer digital tuner in it (you can find out by googling the tv model number) You will need a converter box.
Posted on Aug 25, 2019
5 Related Answers
Anonymous
SOURCE: tv/digital converter box & vcr-dvd hook-up
ATT:Max Parker GLAD SOMEONE ELSE COULD USE THE SOLUTION MIKE CAME UP WITH
IT'S ALWAYS NICE TO KNOW YOUR NOT ALONE IN THE WORLD
Posted on Nov 17, 2008
Anonymous
  • 3 Answers
SOURCE: Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Posted on Feb 18, 2009
Anonymous
SOURCE: Converter box turns off by itself when watching tv.
Check the settings in the menu--many boxes have "power save" mode and will shut off after anywhere from 2-12 hours of inactivity. You should be able disable it or change it to a longer time.
Posted on Mar 14, 2009
joboo1
Jim London
  • 257 Answers
SOURCE: Does my Trutech PLV16190 require a digital converter box?
Hi, Please don't shoot the messenger, you asked but unfortunately the answer is yes. Your tv has an NTSC tuner which is an analog tuner, Sorry. But this should answer your question.
Posted on Mar 25, 2009
Anonymous
SOURCE: Hook up old tv antenna to converter box
how can i connect inside anntena to the tv and converter box?
Posted on Oct 16, 2009
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
Do i need a convert box for my tv
If your tv is not digital and you only watch tv off a tv antenna then you will need a converter box
May 28, 2010 | Mitsubishi WS-48311 48" Rear Projection...
How to connect tv set to digial tv tuner converter box
There are two ways to connect a converter box.
The simplest is to use the RF antenna cable supplied with the converter. Connect it from the box (the round threaded connector) to the TV's antenna/cable input connector and put the TV on channel 3 or 4 (whichever the converter box is set to). If your set has screw terminals for the antenna connection, you'll need an adapter to switch from the round cable connection to the screws. This may also have been supplied, but you'll probably need to pick one up at Radio Shack or another retailer.
The other way, if your TV has the inputs, is to use the audio/video output jacks on the converter. Again, the cable is usually supplied with the box. This direct connection gives better picture and sound quality than the RF method. The jacks are color coded: red and white for the audio right and left channels, yellow for video. Just connect them to the matching jacks on the TV and select the video input to watch the box. (If your TV is mono and has only a single white audio input jack, you'll need a Y-adapter to join the two audio signals from the box into one. This is also available at Radio Shack. If you don't do this, you'll only get one channel of the sound when watching a stereo channel.)
Please take a moment to rate this solution if you found it satisfactory. Thanks for asking!
Jan 25, 2009 | Quasar SP-2723 27" TV
I have Rabbit Ears on an analog TV using a Zenith digital converter box. But how do I tape a TV show on my VCR that I'm not watching? I purchased another digital converter box to attach to the VCR but what...
The only way you can tape a different show than you're watching is to do as you have done: purchase a second converter box and connect it to the VCR as you did with the TV. You can pick up a device called a splitter which will allow you to divide the antenna signal between the two boxes.
There are some problems with the splitter arrangement. If you need to adjust the antenna position to get a good signal on one channel, like the one you want to watch, that may mean it isn't in the best position for another, like the one you want to record. You might need two antennas for the best performance.
Also, you can't program recording on different channels at different times unless you'll be home to change channels on the converter box. The VCR will only find a signal on channel 3 or 4, depending on how you set up the box, and you'll always record on that channel. The TV channel you record will be chosen by the converter.
Finally, you need to connect both the VCR and the converter box to a single antenna connection on your TV. There are two ways to do this. One is to use a splitter again. Normally they are used to split a single antenna input to two ouputs, but they can also combine to inputs into one output (basically you just use it backwards). Connect the ouputs from the box and VCR to the splitter's output connectors, and then go from the splitter's input connector to the TV antenna connector. This arrangement may not give the best picture quality, though. An alternative is to use an "A/B" switch, which allows you to choose which source connects to the TV.
It sounds more complicated to hook up than it actually is. It is more complicated and less flexible to use this setup than it was before the switch to digital broadcasting, but they call this "progress."
Hope this helps. If you need more information, just post a followup comment!
Nov 29, 2008 | Insignia Digital-to-Analog Converter for...
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
Hand held casio tv vs digital signal
A few other tips:
Apr 29, 2008 | Televison & Video
TV Converter Box
Yes, you will need one if you watch any TV from an antenna. If you use satelite or cable to get your local TV stations, then you are good.
Mar 27, 2008 | Sylvania 6720FDF
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
