Question about Canon Office Equipment & Supplies
Just purchased a used Canon PC981 copier w/ no manual. Can't get it to feed my pages to be copied through the top.Keep getting the paper jam signal-this goes away if I remove the paper - can you help?
It makes copies if I lift the top and place directly on glass, but will not feed to the glass-
Posted by Lynne Breister on
Tom Chichester
    Top Expert:
  • Canon Master
  • 56,023 Answers
The document feeder is damaged, misadjusted, or both..
Posted on Aug 25, 2019
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: cannon imageclass mf5550 troubleshooting
The document feeder on this machine uses a separation and a feed roller ,the pad is on the bottom and the roller sits on top . in most cases the pad will be white if it is not it must be cleaned .use isopropyl alcohol. then clean the roller using water on a paper towel. On the tray issue if the paper is torn or nicked the sensor flag may be damaged if it is you will need a service call . if the paper is not nicked check to see if the default paper size has been programmed into the user settings on the copier [ read the owners man.] When you send a print to the printer go to printing preferences and check on the paper size being sent to the printer it must match the paper size loaded into the machine
Posted on Jan 23, 2008
Anonymous
  • 153 Answers
SOURCE: canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Posted on Apr 09, 2009
goalie39
Ed
  • 479 Answers
SOURCE: Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Posted on Apr 28, 2009
Anonymous
  • 15 Answers
SOURCE: Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Posted on Jun 09, 2009
Anonymous
SOURCE: HP 7410 streaks when using auto document feeder to make copies
Lift the cover of the fax/scanner/copier. The glass area has 2 sections, a small section and a large section. Clean the small glass section with damp cloth. I had 3 black streaks caused by 3 black dots on that glass. I also cleaned the rollers on the ADF, but that was not the problem.
Posted on Jun 27, 2009
When im making copies it will run off 4-5 pages and the jam up, i keep un jamming it and it keeps happening any ideas whats wrong?
Sounds as though the feed rollers for that particular paper drawer/cassette is in need of replacement.
Mar 28, 2011 | Canon NP 6545 Copier
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on [email protected], if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
I have a Canon PC790 and every time I try to copy, I get an error message in the paper select part of the control panel. I checked for a paper jam, seems like it isn't picking up the paper. I can't find...
Remove the paper tray and clean the feed rollers on the right side at top. I would use a cotton ball with rubbing alcohol on it. Make sure the rollers are dry before trying to copy again. Let me know your progress.
Nov 02, 2009 | Canon PC-921 Black and White Copier
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Adf
Is it showing a paper jam? Did you look for any small piece of paper jammed in it or a paper clip? There are a few parts that may have to be replaced, like the paper feed rollers. Dose it try to pull the paper in? You might be looking at a costly repair if the service person has to change the drive motor or the main PCB. Sorry to bring bad news, but it may be some thing simple. I have had some that just did not want to be fixed. Good Luck
Jan 30, 2009 | Office Equipment & Supplies
Canon pc980 dF error
Page 62 of PS980 manual shows how to get rid of the dF error, and it worked for me just now. If you can't see any paper causing a jam, there could be a small piece of paper above the white feeding belt. 1) turn off copier, lift lid, and gently pull the feeding belt. If nothing falls out and you still get the error, 2) insert a postcard to the left of the feeding belt and wiggle vertically and horizontally. To my surprise, a small piece of paper I had copied and forgotten about emerged on top of the copier lid!
May 08, 2008 | Canon PC-980 Color Copier
Cannon imageclass mf5550 troubleshooting
Jan 02, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Error message for auto feed
the rubber feed wheels need cleaning with high purity alcohol
Dec 17, 2006 | Canon PC981 Copier
16 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
