How to hook up speakers to TV. Can I hook passive speakers to a headphone amp
Franco Dosil
    Top Expert:
  • Audio Player... Master
  • 10,535 Answers
Hi Anonymous, connect passive speakers to a headphone amplifier, it will not work, the headphone amplifier is designed for that, headphones, they are very low power
You should use an amplifier, according to the power that your speakers can handle or use active speakers
I hope you can hear the sound of your TV on your speakers
Regards Franco Dosil
Hola Anonymous, conectar altavoces pasivos a un amplificador de auriculares, no va a funcionar, el amplificador de auriculares esta pensado para eso, auriculares, son de muy baja potencia
Deberas usar un amplificador, acorde a la potencia que puedan manejar tus altavoces o usar altavoces activos
Espero puedas escuchar en tus bafles el sonido de tu TV
Saludos Franco Dosil
Posted on Aug 24, 2019
Testimonial: "Thank you Franco Dosil I thought that but wasn't sure ."
  • Franco Dosil Aug 28, 2019
    Well, that you can enjoy the sound of your TV in your speakers
    regards
    Bien, que puedas disfrutar del sonido de tu TV en tus Bafles
    Saludos
    Thank you for rating my answer.
    Gracias por valorar mi respuesta
5 Related Answers
Joel Friedenberg
  • 1114 Answers
SOURCE: passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Posted on Jul 24, 2009
Fred Yearian
  • 5603 Answers
SOURCE: i have four active and two passive speakers how
Assuming they are ALL mains and not for monitors connect this way:
Connect the passive to the A and B powered outputs. Please read my tip on Fixya regarding hazard of grounding speaker leads on channel A of PMP mixers.
Connect each pair of active speakers to the Main L and R 1/4 inch jacks using TRS balanced cables. Power these speakers from the SAME receptacle or source, even if it means running an extension cord to your mixer from where the actives are plugged in. FAILURE to do this creates a hazard of ground loops and ground bounce that can damage equipment. The Main L and R 1/4 inch jackls can drive more than one active speaker... these are line level signals. Make sure to use TRS balanced cables for this.
Posted on Nov 10, 2010
Testimonial: "u guys are great thanks"
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: Im trying to hook up two sets of passive speaker,
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Posted on Nov 27, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: I have an emerson lcd
simply put .no. the only way of doing this is to have a tech run a line inside the tv to the speakers using a 3.5 mil phono jack with speaker cut off
merry christmas
Posted on Dec 21, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: My new TV only has
a little google goes a long way...
"headphones optical digital"
Some wireless DO work and even simulate 5.1 surround
http://www.amazon.com/Sony-MDR-DS3000-Wireless-Surround-Headphones/dp/B00023C6SE
Posted on Jan 31, 2011
What do I have to do to hookup a headphone to my 60 in vizio TV?
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Feb 23, 2017 | Vizio Televison & Video
How to connect external speakers to RCA 22LA45RQD
Your TV has a headphone jack. This can be used to connect it to a receiver or audio amp to drive external speakers or it can be directly hooked up to a powered speaker.
Sep 21, 2013 | RCA 22LA45RQD LCD TV/DVD Combo
How do I hook up passive subs to my board
Sub outs needs an active speaker.
An active speaker have a built in amplifier and preamplifier.
For a passive speaker it needs an amplifier.
Oct 01, 2012 | Mackie 2404-VLZ3 Mixer
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Bought a powered monitor as it said to do in the owner's manual, even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked...
You haven't mentioned what model and manufacturer the mixer is. I will have to guess and say that the monitor out on the board isn't providing signal to the powered monitor or the monitor out on your board is powered and is now damaged by plugging a powered monitor into it. Carefully reread your manual and determine if the monitor out on your mixer is powered or line level. Reread also and make sure that the signal you are monitoring is assigned to monitor out, levelled correctly etc. If you find that the monitor out is passive (line level) try hooking it up to an external power amp and speaker. A guitar amp will do for testing purposes. Start with a low input volume on the amp. Also make sure that if it is passive to use a shielded cable from monitor out to input. If your board has powered monitor outs you can use a speaker cable from monitor out to speaker input (non powered monitor speaker).
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
Passive radiator speaker wiring
Jul 23, 2009 | Audio Players & Recorders
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
