Question about Furniture
How to change the 9vbattery in my Lazyboy recliner
Posted by Thelma Hamer on
1 Related Answer
bordercol565
bordercol565
SOURCE: I'm thinking of getting the full reclining lazyboy loveseats, how much space I need to leave between the chairs and the wall?
depends if u have kids. i usually put bout 1inch away from the wall and i have a 3yo i guess the older ur kids are the closer to the wall you can get seing as they wouldnt run around or jump on furniture as much.
Posted on May 29, 2012
How do i dismantle a recliner 3 seater leather setee
On Lazyboy products you can pull up on the seat back and it will come apart, so you might try pulling this out from the wall, get behind it, grasp one section one either side and pull straight up.
Aug 12, 2014 | Furniture
Ashley furniture reclining loveseat power cord
Many of their power supply parts have changed requiring all electrical parts to be changed out. I might have a slightly used one if I know the numbers on the part. If not you can call Ashley customer service and request new kit for around 200. You need the serial number on the bottom of the chair.
Jun 02, 2014 | Ashley Furniture EXHILARATION 2 SEAT...
Lazyboy recliner foot rest will not stay up!
Check the spring that holds the foot rest closed or open. Flip the chair over and take a look.
Mar 30, 2014 | Furniture
Rollers on lazyboy reclina rocker
Lazy Boy recliners usually have a lifetime warranty but I beleive that it is for only the parts not the labor. I had the same problem and went to the dealer asking the same question. They gave me a number to call to have the parts shipped to me. We ended up buying a new couch instead for other reasons so I never tried calling the number. You should call your local retailer and get the number and see what they will charge you to install them for you if you can do it yourself.
Mar 25, 2014 | Cars & Trucks
Change the position from recline
Hi Claire
Stand in front of the Buzz chassis at the front wheel. On either side of the seat unit you have a grey button. Push the button down and now you recline the seat / sit it upright as required.
http://www.quinny.com/-/media/Quinny/Product%20content/Manuals%20and%20instructions/buzz/MAN_DRU1074A14_Q_BUZZ_V1_2014_ENFRDENLESITPTKOPLELRUCS.pdf
Jan 16, 2014 | Quinny Buzz Three Wheel Stroller
If it is fully reclining you need to leave a little bit more than the height of the chair's back. For example: if the back height is 19", then you need to leave about 20" between the chair and the wall behind it.
May 29, 2012 | Furniture
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Jul 22, 2008 | 2000 Ford Focus
Furniture Logo
146 people viewed this question
Top Furniture Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Furniture Expert? Answer questions, earn points and help others
