Lid does not lock and machine stays on sensing. Takes water but no agitations
Posted by Sarah Begnaud on
ray gallant
    Top Expert:
  • Washing Mach... Master
  • 68,539 Answers
Call your local repair service as we know not what you have .
Posted on Aug 24, 2019
5 Related Answers
Anonymous
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
sarmed kasim
SOURCE: lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
Posted on Jan 26, 2012
luisa_sgro
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
SOURCE: I have a whirlpool washing
I have a Whirlpool model WTW4950XW0. Once i push the start button.
The lid locks, sensing lite on, machine goes through its cycle, than lid unlocks
monents later.What wrong. I was doing laundry and notice the machine making some noise on the spin cycle. I push the pause button and remove some clothes.
thats when the sensing lite keeps blinking.
thanks
Rich
Posted on Oct 16, 2012
richroth
Richard Roth
  • 9472 Answers
SOURCE: amana washer stuck on sensing
What is the model number of the unit?
Posted on Nov 25, 2012
May tag centennial top load washer will not agitate clothes
The most common cause of this is a defective washer lid switch. Follow the link for a repair guide. How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Jul 13, 2017 | Washing Machines
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Washer fills with water and then stops
Most washers will fill with the lid open.
Then, the lid has to be closed for it to start agitating.
This is sensed by a switch for the lid.
The lid safety switch is where I'd start to look at.
Oct 05, 2013 | LG Kirkland
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
It is new and it will not even start the drum rotating in the sensing (initial) start up
The drum doesn't rotate in the sensing stage. This is when the washer is determining how much water will be needed based on the weight of the items in the washer. Once it has been determined, the water will go into the machine and THEN the agitation will begin.That's why the lid locks during the sensing stage: so we don't keep adding another item or two because that will throw off the calculations the machine is making when it's "sensing." My Cabrio is less than a year old and I still want to open the lid to see if there's enough water in there. But that's no longer necessary with all this new technology.
I hope this helps you out! If it does, please come back to Fixya and rate my advice. Thanks!
Jul 29, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool top loading washer doesn't agitate
The agitator dogs only make the top part of the agitator work. you can check the dogs by grabbing the top of the agitator and turning it right then left. If it doesnt lock when turned back the other direction they are bad. If thats not it, it could be your drive coupler. But its only the drive coupler if it doesnt spin. Also check the lid switch. But if its the lid switch Your washer will stay full of water and not drain out. But check your dogs. There are cheap and thats probably your problem.
Nov 16, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
