Question about Home
How does one calibrate the Polder Stainless Steel Ultra Slim Digital Kitchen Scale?. The model is ITM/ART 882840.
I don't have the manual so I don't know how to calibrate it. I suppose you'd have to press some kind of sequence with the power button, apart from that I've no idea. It doesn't have a mode button like most kitchen scales, which is used to change the metric unit and also to calibrate the scales. Instead this scale changes the metric unit with the power button itself.
Posted by victor on
5 Related Answers
Anonymous
SOURCE: setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Posted on Nov 21, 2008
Anonymous
SOURCE: I have a tanita tbf-612
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
Anonymous
  • 30 Answers
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Posted on Aug 21, 2009
LaidlawUk
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
fb62685
fb62685
  • 4 Answers
SOURCE: My Terallion electronic kitchen scale shows an out2 error
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
How do i change from g to lb on Polder KSC-345-95 Stainless Steel Kitchen Scale
After searching, no manual can be found. You can however contact their customer service using the information from here: http://www.polder.com/contact
Mar 06, 2015 | Health & Beauty
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
I have the thin kitchen scale. After changing the battery, the display keeps flashing. How do I get the scale to work again?
I had the same problem, I am not sure why but it seems like the circuits misfire when you change the batteries (perhaps a capacitor holding a charge or a diode stuck).
I got mine working again when I put the batteries in backwards (trying to discharge any capacitor that might be holding a small charge still) and then hit the power button with the batteries in backwards; then put the batteries in properly and hit power again.
please note that I am NOT an electronics professional and I have no idea if this is harmful to the scale or not, but it worked for me and the Polder scale is working as designed once I did the procedure. Hope it helps.
Jun 24, 2014 | Polder Slimmer Digital Scale
Replaced three batteries in polder kitchen scale, now it just flashes light. Can't turn on or off and no digital readings
Be sure all 3 batteries are fresh and also be sure they are in correctly .positive+ and negative- , to proper placement in machine. Typically the spring contact points go on the flat -end of battery and the + nipple end of battery goes on the solid or button contact on the machine. Spring end contact points on machine may be an actual spring or a raised metal piece either way they are the end that flexes and holds the battery tight against both contact points. Sometimes the spring must be carefully pulled to make it give more holding pressure. Good luck and I always say Google it!
Oct 18, 2017 | Polder KSC-310-28 Easy-Read Digital...
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
Polder kitchen timer instructions
Timer is not identified for certain
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical manual:
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 06, 2011 | Polder Triple Digital Timer Model 891-90
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Home Logo
180 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
