What is an EA ERROR Code in Whirpool Washing Machine?
Posted by Anthony Yenko on
teinesamoa
    Habit-Forming:
  • 39 Answers
Are you having problems with your washer?
Posted on Aug 24, 2019
5 Related Answers
romsky79
rommel dadulla
  • 822 Answers
SOURCE: Whirpool Washing Machine Front Loader. The
you can get your bearings by way of removing back cover first.
Posted on Aug 09, 2009
Prakash R
  • 1382 Answers
SOURCE: whirpool duet washer - error code f35. shuts off
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Posted on Jul 27, 2010
Rene J Solis
  • 1796 Answers
SOURCE: I am having F1 error
Hi!!
F1 Board failure Replace control board (also called ERC or clock).
Although the manufacturer recommends to replace the control board. I've learned that if you unplug the unit from the wall outlet for a couple of minutes, most of the time the board will reset.
Try that and keep me posted!
Posted on Sep 21, 2010
AndrexT
Andrew Taylor
  • 33395 Answers
SOURCE: Washing machine EWT704S keeps displaying error code EA.
Found this
Re: Samsung B1113J "error code EA" A Tech I called said auto sensor was the tach on the motor.
Check for proper resistance across pins 3&4 at the motor plug (2 red wires). Should be 150 ohms.
If proper resistance, could check connections at board and board itself.
Though I wonder what the error would be if the motor wasn't turning and this looked like an error with the tach. Would this this be an EA error too?
Posted on Jan 06, 2016
emissionwiz
Marvin
  • 85239 Answers
SOURCE: EA error on electrolux EWT854S washing machine?
Please recheck that code, no EA is listed. Go to the link to read code difinitions. https://electro-medical.blogspot.com/2016/06/electrolux-washing-machine-error-codes.html
Posted on Jan 27, 2017
Whirpool f5e2
What is a "duest"
Aug 03, 2018 | Washing Machines
Found this
Jan 06, 2016 | Washing Machines
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Whirpool washer F08 error code
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Feb 02, 2010 | Washing Machines
Whirpool Duet Washing machine F-11 error
I purchased a Whirpool duel washing machine Aug 05. In June of 08 it showed an F11 error. After factory repair service tech. looked at it he said that i needed a main motor at a cost of $400.00 After search on internet many people reported problems also and decided not to repair it. Has any one had problems with theirs?Ihave the same problem is there any solution????please help
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool error h23
h23 is a fault code , refer to your machine handbook for explanation of these codes.
Nov 09, 2009 | Washing Machines
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
