Question about Refrigerators
Model # ed5vhexvbo1 ice maker not making ice. worked fine yesterday, told me to change water filter which I did today, still not making ice. is there a reset button for the ice maker for this model
Posted by Laurie Matthews on
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
David Coomer
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
Anonymous
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
Cary Crook
  • 105 Answers
SOURCE: Whirlpool Gold Ice Maker problem Model # GS6NBEXRS00
I hate to ask the obvious but is your water supply turned back on since the filter change?
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Feb 10, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
Posted on May 30, 2009
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
Gsh25sgpass ice maker not working, water leaking
The WR57X10051 Dual Water Control Valve located on the rear and near floor is the problem. Part location 800 in photo here=> GSH25SGPASS Component Parts Change out the WR57X10051 Dual Water Control Valve and this problem will be solved. When this valve wears they will begin to leak slowly causing a mess inside freezer and ice maker. If you have questions I will be here to answer them, Thanks Sea Breeze
May 24, 2012 | Refrigerators
Frigidaire refrigerator FRS26LH5DQO problem: Water in door quit today - worked yesterday. Ice maker has plenty of ice but am not sure it is currently making ice?
I had the exact same problem. Very simple fix. Change the water filter. About $30 at the appliance parts store.
Jan 05, 2011 | Kitchen Ranges
Ice maker
So you are not getting water to the ice maker? If not then fill ice maker with water. If when the water freezes and the ice maker dumps then the water control valve on the back of the refrigerator is defective. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
