Sewing Machines Logo
Question about PfaFF Sewing Machines
Pfaff 2056 thread stuck in and broke off in the tension guide. I couldn't pull it out. Is there a way to take off the side cover?
Posted by Terry Clark on
5 Related Answers
oldun1
SOURCE: Automatic Threading not working
if you damp the end of the thread this seems to cure this
Jan
Leighton buzzard
Posted on Feb 28, 2008
Anonymous
  • 10 Answers
SOURCE: Tension has thread caught in it.
Hope this helps. In the order I would recommend:
  1. "Floss" the tension disks - this is nothing more than running a heavy thread (12 weight or upholstery) through the thread path, grasping the thread at the spool and the end that is through the needle and "flossing" just like you would your teeth - slide the thread back and forth through the disks/thread path. This will often-times pull through whatever is stuck!
  2. If the thread is more deeply tangled than "flossing" will fix, you CAN remove the top of the machine to better see it. I would, however, recommend you take the machine to a Pfaff-trained tech if this is the case - things that can be damaged if you're not trained on the machine. However, if you're wanting to give it a try (the thread may be easily visible and easy to get to):
    • Remove the stitch lid - there are little metal clips at the base of the lid that you can push outwards to remove the lid - can't get the top off without removing lid.
    • In the well of the machine top are a few screws (2 if I'm remembering correctly). The screws are star-shaped as opposed to Phillips or Flat - special screwdriver is required. Just make sure you don't remove the screw that's holding the bobbin-winding mechanism on.
    • Once the screws are loosened, you'll have to maneuver the top out of it's position - this requires a little wiggling but is not impossible (just impossible to describe how to wiggle it!!)
    • Turn machine OFF and UNPLUG it. Too many electrical connection points you will be working around to take a chance!
    • VERY CAREFULLY... turn the handwheel towards you (never turn backwards) until you are able to view the entire race/thread path. If you can EASILY remove the stuck thread, go ahead and do it. If you have to do too much pulling and tugging, be VERY careful - if the thread is wrapped around the check spring, you may bend/break it.
Again - hope this helps!
Happy sewing,
Kim
Posted on May 04, 2008
Anonymous
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
Anonymous
  • 53 Answers
SOURCE: Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Posted on Jun 06, 2010
1helpful
Re. Pfaff Expression Lifestyle 2022 machine
It sounds like the bobbin tension is too tight or the top tension is too loose. It is a delicate pulling game that needs to be just right. Bird nesting is a sure sign of tension issues.
https://www.google.com/search?q=setting+bobbin+tension
How do I disable the bobbin thread low feature on my Pfaff Performance 2056? I am trying to make paper stencils. Thanks.
I have a 2056. I open the little door with the red light and closely watch my top thread for when it stops catching a bobbin thread until it is used up. I stitch more slowly but at least not annoyed and not wasting thread. Dawn Illinois
How do I thread hobby grand quilter 1200
The Hobby 1200 is a Pfaff sewing machine that they call the Grand Quilter. First raise the presser foot and make sure that the needle is at the highest position (press the needle up/down button twice with the machine on). Then turn off the machine and unplug it for the maximum safety. For the top thread, place a spool on the spool pin and guide the thread through one of the two thread guides on the thread guide bar. The thread starts from behind the guide. (The post holding the guide bar is next to the spool pin.) As with most sewing machines, you will work from right to left and lead the thread down then up before going down to the needle. Bring the thread to the next thread guide (in front of the bobbin winding pin) and pass it through one of the holes from the back. Wrap the thread to the back of the guide and then through another of the holes. If the thread tension is very loose, try going through all three holes. Bring the thread down between the pre-tension discs going counter-clockwise.
Hold the thread in both hands and guide it around down and around the tension dial from right to left. Bring the thread up to get it between the tension discs and behind the tail of the check spring. Bring the thread back down over the loop of the check spring then under the thread guide that looks like an upside down L with a curve in it. Bring the thread up and through the next thread guide. (This guide is horizontal and just above the previous guide and one side ends near the center of the tension dial.)
Bring the thread up and pass it through the eye in the thread take-up lever and then back down through the horizontal thread guide above. Slip the thread into the thread guide and then down to the needle bar thread guide. Thread the needle from front to back. The thread should be along the groove in the needle.
You can find the manual at Pfaff's Machine Update page: http://www.pfaff.com/en-US/Support-and-Updates/Support . Search for the model and then you'll get to the product page: http://www.pfaff.com/en-US/Support/3336 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/GrandQuilter-manual-EN.pdf . The threading section starts on page 21 (page 23 of the PDF). The manual has good pictures that are better than my attempts to describe the guides.
I hope this helps.
How do you remove the faceplate on a euro pro 376
Some machines (computerized models) are made so that the outer covers cannot be removed. Are you able to remove the side cover over the needle bar? You may be able to find the problem there. Otherwise, you may need to have service performed. The thread could be hanging up in the tension guides--most likely pieces of thread.
You might try cleaning the tension guides. RAISE the presser foot, loosen the upper tension as much as possible. Then gently pull a length of unwaxed dental floss through the tension mechanism a few times. If that doesn't work, there may be something really stuck that needs a technician to resolve.
Just FYI--ALWAYS raise the presser foot before threading the upper thread. This releases the tension disks so the thread will seat properly.
The bottom tension on my Pfaff 2056 sewing machine is loose and keeps jamming up.
check the top tension try a 3 or 4 but I wouldn't go any higher than 5
also put in a new needle
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
1helpful
2answers
2056 the understitch is loose. Is this a problem wit the tension ?
Sounds like a threading problem. Thread the machine all the way to the needle but not the needle eye. Then pull on the thread and lift the presser foot up and down. You should have tension when it is down and no tension when it is up. If this is the case try sewing, should fix the problem. If this is not the case your machine will need to be adjusted buy your pfaff dealer.
Hope this helps
12helpful
2answers
Threading a pfaff 9020 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
2helpful
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
set your tension to 5 and try it.
sewman7
Thread bunches under the material
There ARE still parts for your 7570 - amazing how rumors can get around!
Could be any number of things - from something as simple as a thread caught somewhere in the upper/lower tensions to the tension assembly to timing to any number of other things? You may have already tried some of these - hope this helps:
  1. Try "flossing" your upper tension - this is nothing more than running a heavyweight thread (such as upholstery or 12 weight thread) through the threading paths. Grasp the thread at the beginning of the threading path and the end coming through the needle and "FLOSS" (back and forth - just like you do your teeth). This will usually pull through anything that is gently stuck.
  2. Pretty much the same thing for the bobbin thread - if you're comfortable doing so, loosen the tension screw on the side of the bobbin case to make sure there aren't any little bits of thread fuzz stuck under the tension plate on the side of the bobbin case.
  3. Also remove the needle plate to allow you to better see the upper part of the bobbin system - if there are any bits of thread, etc. stuck in there, you may be able to see them and pull out with tweezers (turn machine off before you do this so the tweezers don't accidentally come into contact with anything).
If this doesn't work, you'll need to have a sewing machine tech look at it (I would recommend a Pfaff-trained tech as they're going to be the most familiar with your machine). The 2140/2144/2170 use most of the same parts - even the new CV still uses some of the same parts.
Good Luck,
Kim
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
