Question about Motorola Mobility RAZR V3i Cellular Phone
R2608 troubleshoot chair please help with adjusting seat. It only goes up having trouble getting it to stay up PLEASE SEND HELP THANK YOU
R2608 troubleshoot
Posted by Rae'Dawn Woodberry on
I bought a TP 4000 chair at Staples today and when you sit in it you immediately sink like the hydraulic cylinder that allows you to adjust hieght is bad. Any ideas??
It could be faulty, but there is a arm under the seat that should allow you to adjust it, exercise that lever, perhaps the valve is stuck.
Jan 02, 2015 | Seat Cars & Trucks
My jet3 ultra won't stay on
Chances are you batteries are beyond their usable life and need replacement -OR- you have a disconnect between either battery and the chair. Please check to make sure the circuit breaker isn't popped, all the fuses under the shrink-wrap on the positive terminals are good and that the battery connectors are seated properly. If the batteries each measure 12-14 volts at the battery post while the chair is plugged in and either drop below 10volts when unplugged then your batteries need replacing.
Mar 07, 2014 | Jet 3 Ultra Power Chair
HOW DO I FIX MY OFFICE BOSS CHAIR IT LEANS BACKWARDS AND WON'T STAY STRAIGHT
without sounding like a smart ***, have you checked the adjustors under the seat. Some handles are 3way handles and can do multiple adjustments. If you have adjusted all the knobs and handles, maybe it is leaking gas or in some case oil. Some of these chairs have an extra knob at the back of the seat along the column of the back rest, as to lock it in the desired position. Good luck.
Jun 01, 2012 | Furniture
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
I wouuld suspect a controller problem Since the programming is in the controller and it suddenly changed your operation I would expect something screwed up the controller. Have your provider check it with an Invacare programmer to make sure that the settings for your chair are correct in the controller. If Medicare paid for your chair then you can contact Roadrunner Mobility @ 1-800-467-2668 and have them send out a tech to work on your chair. They will bill Medicare for most of the repair costs Hope this helps
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
One till is frozen when i reboot while the othere has a plane white screen, any ideas????
Hello
Thank you for using
FixYa for your problem
It could be just a loose connector on the back of the computer.
It could also be malicious software. Scan the computer with a virus checker.
Otherwise, it could be either the monitor or the video card in the computer.
Try the following to find out which:
- Swap monitors with another compatible computer, and see if the trouble stays with the computer, or goes with the monitor. If the trouble stays, replace the video card. If the trouble goes, replace the monitor or have it repaired.
- Arrange the power connections so the monitor stays on when you shut down the system. If the trouble goes away when you reboot, then you need a new video card (much cheaper than a monitor).
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 06, 2009 | Computers & Internet
Bread pan will not seat properly in the machine
The breadpan has warped from the heat of the maker (the only way to fix it is to get a new pan) Call the company for a FREE replacment! have a good new year
Please rate answer response and help keep this site free!
Thank You!
Jan 02, 2009 | Breadman TR500 Bread Maker
Harness straps
well all u doo is u should look on the see or manual and read or go online to see the manual
Aug 08, 2008 | Evenflo Embrace
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
