Question about Honda Garden
How do you set adown loader valve on a pressure washer generac with honda motor
Posted by Russell Bentley on
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: on a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Posted on Mar 27, 2009
Bill
  • 30 Answers
SOURCE: I need the owner's manual for Generac Power Washer
Here is the link for your machine.
http://www.generac-portables.com/document/index.cfm?doc=1439_0EN3W_LO.pdf
Posted on Apr 11, 2009
Anonymous
  • 174 Answers
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
Posted on Jun 05, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: will crank but runs rought them cuts off
Sounds like water in the fuel, or old gas. Drain the tank into a suitable waste container. Drain the carburetor float bowl, and the fuel line. Reattach the fuel line, and clean the float bowl out. (BE careful of the float bowl gasket!)
Replace the float bowl, and add fresh gasoline. I would use at least 91 octane. (NO gasohol!)
You may have to run it for a while to straighten it out.
Also remove the spark plug, and see if deposits have built up on the center and side electrode.
Todays gasoline has all kinds of additives in it. Some are designed to keep deposits from building up so much. (In truth, all gasoline is the same)
These small engines, usually require changing the spark plug at regular intervals.
Posted on Jun 07, 2009
Anonymous
  • 384 Answers
SOURCE: I have a Generac pressure washer, model #01450-0,
Take a small diameter wire and poke thru the discharge hole of the spray head to clean out.
Second time in 6 months that I had the same problem. The problem is alway in the spray head.
Posted on Jul 24, 2009
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
My Generac pressure washer will work great for as long as I hold the trigger. If I release the trigger to move something or change positions and then pull the trigger again the pressure doesn't come...
Sounds like the unloader valve built-in to your system is sticky. Try lowering the pressure of the regulator to lowest setting then re-adjusting. This will place a different pressure /load on the valve. Also when you store your unit, displace the water in the pump with oil so that lubricant will prevent the unloader from sticking. If you continue to have problem, replace the unloader. Good luck
Jun 30, 2011 | Briggs & Stratton Power Products 1539...
My pressure washer stops running when i let off the trigger
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
May 30, 2011 | Honda Pressure Washer PSI 3000
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
GENERAC POWER WASHER PUMP
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
Sep 10, 2009 | Plumbing
I have a Generac pressure washer, model #01450-0, with a Honda 5hp motor. The motor runs fine, but the pressure hose pulsates as if the pump is intermittently making pressure, and the pressure out of the...
Jul 23, 2009 | Garden
On a generac pressure washer that works fine.
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Garden Logo
73 people viewed this question
Top Honda Garden Experts
JOHN LAPIER
Marvin
Marvin
Tim Venetis
Are you a Honda Garden Expert? Answer questions, earn points and help others
