Badgy 200 card counter printing or does the ribbon roll have a card counter that restricts the reuse of ribbon rolls?
SOURCE: TAKE UP RIBBON
I work with Zebra printers daily and I have found several ways to enable a stuborn ribbon motor. The S300 is the hardest to turn on but unless the belt has broken or come off it can be done. The S400 and S600 are much easier, below are a couple step that work for me.
Enabling/Disabling the Ribbon motor
• Turn off the printer.
• Disabling the motor – Press the FEED, CANCEL and MODE buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out.
• Enabling the motor – Open the printhead and retract the ribbon completely onto the supply spool. Leave the printhead open. Press the PAUSE, FEED and CANCEL buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out. When the printhead light begins to blink, reinstall the ribbon and close the printhead.
The printer may or may not print out a ribbon sensor profile, this is normal. Cycle the power and you should be good to go.
SOURCE: MY SONY UP-10L SNAPLAB PRINTER GIVES ME THE
Hi
This sounds like the sensors are damaged. Best taking to a computer repair centre to be checked out as sony parts can be hard to acquire.
Thanks
Taz
SOURCE: DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
SOURCE: My Canon AE-1 Program will not rewind. I shot the
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
SOURCE: Zebra P330i Printer not counting the YMCKO ribbon correctly
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
