Question about Homelite Garden
Homelite UT15019,looking for.a.diagram that shows routing of throttle cable at carb? And how the choke is connected? Thanks Dean
Posted by Dean Burton on
Tom Chichester
    Top Expert:
  • Homelite Master
  • 55,960 Answers
Maybe Homelite can help with your search.
Posted on Aug 23, 2019
5 Related Answers
1400Slugg
  • 260 Answers
SOURCE: choke on a suzuki gs1100 gk /mikuni 34mm carbs
cables too tight , poor lubrication of choke and or throttle cable
Posted on Dec 16, 2008
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
Anonymous
SOURCE: i have a 2004 yamaha blaster 200 i need a diagram
i can't seem to figure out why my 2004 blaster 200 won't idle properly. i cleaned the carb and replaced the spark plug. it revs fine but when it goes down to idle it just dies. any help?
Posted on Sep 10, 2009
Ross Clifton
  • 136 Answers
SOURCE: My Homelite 26b will run at full choke but will
make sure your fuel mixture is correct also check t your air cleaner it will not run right without it or if it extremly dirty
Posted on Oct 25, 2009
SOURCE: wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
Posted on Jun 28, 2010
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
Diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Oct 22, 2012 | Homelite Garden
2005 Kawasaki VN 750 Vulcan choke cable routing
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Choke cable routing Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
1991 Kawasaki Vulcan carb install
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
2005 Kawasaki Vulcan 750 Owner Manual
Jun 09, 2012 | 2005 kawasaki VN 750 Vulcan
I replaced fuel and carb lines on my Poulan 2450 chain saw. I cannot seem to find the correct path/attachment for the throttle connection. Parts diagrams do not show this. Can someone provide a diagram...
It is quite difficult to explain exactly how it fits, the cable always looks too long and has to curl around on itself back to the trigger, the picture shows quite well how it goes, the end of the cable with a dog leg in it goes to the carb, as far as i remember it goes to the upper hole in the carb spindle, just push it into the hole and turn through 90%, the other end fits into the throttle trigger.adw1_9.jpg
Sep 10, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Motor will not start
For some reason the engine is flooded. To make it start do the following: turn the choke off, hold the throttle wide open and crank it until it starts.Do not push the primer bulb first. It already has more fuel than it can burn. It will smoke more than usual until it burns out the excess fuel. You may also have a carb problem but this should allow the engine to start so it can be diagnosed.
Please rate this solution if it helps-
Mar 19, 2009 | Homelite Garden
Choke on a suzuki gs1100 gk /mikuni 34mm carbs
Dec 16, 2008 | 1982 Suzuki GSX 400 FS impulse
Garden Logo
32 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Nick Olsen
Are you a Homelite Garden Expert? Answer questions, earn points and help others
