Hi Ramon, as you say, the protection circuit is working, you would have a problem in the power supply or in the audio outputs of speakers
I suggest you disconnect, all the speakers and test if the fault continues, if it does not continue, connect the speakers one by one and test until the possible fault is detected
If you disconnect and stay the same, I suggest you look for a specialized technical service
If you have knowledge and technical expertise, I give you the link to download the service manual of your Pioneer
I hope you can solve the problem
Regards Franco Dosil
Hola Ram?n, por lo que comentas, esta trabajando el circuito de protecci?n, tendr?as un problema en la fuente de alimentaci?n o en las salidas de audio de parlantes
Te sugiero desconectar, todos los parlantes y probar si continua la falla, si no sigue, conecta de a uno los parlantes y prueba hasta detectar la posible falla
Si desconectas y sigue igual, te sugiero busque un servicio t?cnico especializado
Si tienes conocimientos y pericia t?cnica, te paso el link para que descargues el manual de servicio de tu Pioneer
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/1259236/Pioneer-Vsx-523-K.html
https://elektrotanya.com/pioneer_vsx-523-k_vsx-533_rrv4418_sm.pdf/download.html
