Question about Boating
What year did Doral stop using wood in their hulls?
Posted by Randy Comeau on
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
Doesn't work on fast flowing river
Many depth finders don't work when the transducer sees a little turbulence. My only suggestion is to try different locations for the transducer, trying to guess where there will be the least turbulence beneath it. This is easy if your transducer is mounted inside the hull and reads through the hull. Not so easy if it is a through-hull mount. Be sure it is mounted correctly to the hull if it is mounted inside the hull.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 03, 2017 | Lowrance HDS5x Fishfinders
I neede an instruction booklet on my dorel alexander wm1646c i can't put it together
On the condition that I am not to be held liable for any damages associated with following the instructions that I've scanned and made available, you can find the instructions for the assembly of the Doral wm1646 wm1646c and wm1646w sleigh bed here:
http://www.krenim.org/jeff/WM1646-Dorel-Asia-SRL-Toddler-Bed.pdf
Again, by using these instructions, you agree to not hold me liable for any damages, injuries, or any way liable.
I'm making these instructions available without any warranty.  I simply scanned them and put them into PDF format.
Doral Asia SRL Toddler Bed models WM1646, WM1646C, WM1646W
Sep 01, 2010 | Dorel Alexander
Need instructions for toddler bed dorel wm1646
May 11, 2010 | Dorel Alexander
I need owners manual for a dorel toddlers bed model wm1646c
Apr 23, 2009 | Baby Gear
Scanoe, Ram-X, Split in hull near gunwhales- Repair, How?
I found a Scanoe like this on craigslist that was being given away because of several splits ins the hull. I was ready to buy that patch kit on line when I stumbled on a solution that worked great! I was in Home Depot looking in their pond department and saw some self adhesive patches for poly ponds. I bought on for less than $7.00 and gave it a try. I sanded the inside of the hull around the split. cleaned it well and applied the patch. It worked like a charm!
Oct 20, 2008 | Coleman Sport & Outdoor - Others
Where can I get a kit to convert a Dorel crib to a daybed?
where can i buy 2 parts for my doral model number wm 1633. I lost the 2 sliders on the bottom
Jun 21, 2008 | Dorel Alexander
Boating Logo
131 people viewed this question
Top Boating Experts
ray gallant
Moderator Canada
Moderator Canada
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
