Question about Mercury Boating
I have 65 hp mercury outboard wetting no 3 spark plug .what could be the problem?
Posted by James Robbins on
5 Related Answers
Anonymous
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
Anonymous
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at [email protected].
Posted on Jun 16, 2009
Mark Chapman
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
Anonymous
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
Anonymous
SOURCE: I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Posted on May 20, 2010
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Spark plug gap for 2004 150 hp yamaha outboard
2004 mercury 150hp,v6 2stroke,spark plug gap
Jan 18, 2012 | Boating
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Boating Logo
138 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
