Question about Refrigerators
Westpoint Refrigerator is working and make whereas the freezer is not working and it is warm
Posted by Cledy chavry on
ray gallant
    Top Expert:
  • Refrigerators Master
  • 66,956 Answers
Possibly needs freon added to the system . they do not last forever .
Posted on Mar 26, 2020
5 Related Answers
Anonymous
SOURCE: Refrigerator does not cool
check the defrost themostat (replace) make sure the fan is working and that the defrost heater works as well.see if the timer will run and turn of the heater.
Posted on Aug 17, 2008
Anonymous
SOURCE: Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
Posted on Apr 14, 2009
Ottoniel
  • 202 Answers
SOURCE: FREEZER WORKS BUT REFRIGERATOR SIDE IS WARM
check if fan that blows air to the refridge is working or vent clogged
Posted on Jul 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: kenmore refrigerator not cold but freezer works fine
Here are a couple of tips that I wrote that will help you figure this out...
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Posted on Apr 12, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Posted on May 24, 2010
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
I have a westpoint tropical WRK1802g.1 the freezer always freezes but the fridge side stops working at times and then water runs out from the buttom of the fridge side
If you also have ice buildup in the freezer your temps are not as low as what they should be and your refrig compartment will be warm.
Jul 19, 2015 | Refrigerators
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Hi, there! I have a WESTPOINT no Frost NF 120 and couple of days ago the fridge just stop working. The freezer is ok still working as usual, but the lower part is completly worm. The compressor is working,...
It's the Timer ..a device found on the left of the compressor at the back ..a few wires goes insinde. it has a watch gear mechanism..and a miniscule ant can stop it ..
May 14, 2011 | Refrigerators
Admiral side by side refrigerator model GS 22X8D3 FRIDGE SECTION HAS A POOR COOLING PERFORMANCE, WHEREAS THE FREEZER SECTION WORKS FINE. MOTOR DOES NOT CYCLE ALWAYS ON.
Greetings,
in most self defrosting refrigerators..when the fresh food is warm, but freezer is ok...the first thing to look at is...a frosted or froze over evaporator in freezer. this is because, the cold air comes from freezer into ff section. it comes in and drops to floor of ff and is drawn back into freezer thru coil and if its frozen,,,no air can circulate...remove rear freezer panel and look for ice blockage
There are several other things. A fan motor not coming on will do this.. a stuck closed baffle in ff section can keep air out. check it and if froze up..there is a reason, and you need to find out why or it will happen again...check heater, defrost thermostat, check defrost control
Feb 03, 2011 | Admiral 26 cu. ft. Side-By-Side...
WESTPOINT upright freezer...alarm light blinking
Sir,
I need to know how to adjust WESTPOINT UPRIGHT FREEZER WVR-300W temperature? There is alarm light blinking every time and the temperature is not changing from 4c!!!! Thats mean, the freezer
Sep 29, 2010 | Haier HSE12WNA Top Freezer Refrigerator
Jul 24, 2009 | Magic Chef CTB1821AR Top Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
