Question about Refrigerators
My 21MFTA has a problem in the freezer compartment, where the drain hole at the rear keeps freezing over. It is five years old and problem just started this year.
My previous refrigerator was similar and and developed the same problem. The refrigerator is in an alcove with about 2 inches clearance on each side and about 4 clearance in the back.
Posted by Joseph M Shaw on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 55,379 Answers
Probably the drain tube that leads to the evap pan underneath is clogged
Posted on Aug 22, 2019
Testimonial: "No , I have a spring coil that I run down and out the bottom. No clog. Thanks anyway."
5 Related Answers
Anonymous
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
Anonymous
SOURCE: ROPER RS22AQXMQ SIDE BY SIDE REFRIGERATOR PROBLEM
I had the same problem with a top freezer. I found that the thermostat was bad by tapping on the it at the setting knob. The defrost timer was replaced first which did not help (repairman put in a timer for a Frigadair which will not work in a Roper). If one is used for a frigadair as soon as it cycles it will not work again until it is unplugged and allowed to reset. I replaced both the thermostat and the right defrost timer. It has worked great for over 2 months.
Hope this helps.
Posted on Dec 01, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Posted on Jan 29, 2009
Anonymous
  • 105 Answers
SOURCE: Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Posted on Apr 09, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
I have a 1 1/2 year old fridge, I'm getting a
yes the drain plug hole is blocked.get two pipe cleaners and screw them togather and plunge them down the drain hole to unblock..adrian;;;
Nov 14, 2009 | Refrigerators
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
i think its not the frz drain hole blocking up but a fault with the defrost tray heater. the tray heater should keep the defrosted frost as water to drain away. it sounds as though the tray heater is not working therefore letting the water freeze as it is escaping thorough the drain hole. i would check this out by defrosting the unit and inserting a flexi rod into the otherside of the drain hole (above the compressor usually) and after clearing it if it freezes up again check out the defrost/heater system.
Apr 08, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Jan 03, 2009 | LG LFC25760 French Door Refrigerator
REFRIGERATOR dRAIN stopped up
SOME REFRIGERATORS HAVE A CUP IN THE BACK OF THE FRESH FOOD COMPARTMENT THAT CATCHES THE WATER AS IT COMES FROM THE FREEZER AND SENDS IT DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE DRAIN TUBE OR CUP GETS A RESTRICTION IN IT, IT WILL OVERFLOW AND BRING WATER INTO THE REFRIGERATOR. CHECK THE CUP AND DRAIN TUBE FOR RESTRICTION.
SOME REFRIGERATORS HAVE THE DRAIN TUBE BUILTIN TO THE WALLS OF THE REFRIGERATOR, BUT THE HOLE IN THE FREEZER IS SMALL AND FREEZES OVER. WHEN THE DEFROST CYCLE COMES ON, THERE IS A BUILDUP OF ICE THAT CAUSES THE WATER TO FALL DOWN THROUGH THE AIR DUCT INTO THE FRESH FOOD COMPARTMENT. YOU WILL HAVE TO REMOVE THE BACK WALL OF THE FREEZER AND SEE IF AN ICE BUILDUP UNDER THE COILS IS PRESENT. THEN, REMOVE THE ICE, CLEAR THE DRAIN HOLE, AND SEE IF WATER WILL PASS THROUGH THE DRAIN. A FIX TO PREVENT FREEZEOVER FROM REOCCURING, IS TAKE A PIECE OF BARE COPPER WIRE AND WRAP AROUND THE DEFROST HEATER AND PASS IT DOWN THE DRAIN HOLE (ABOUT FIVE INCHES WILL DO).
WHEN THE DEFROST HEATER COMES ON, IT WILL PASS HEAT DOWN THE WIRE TO KEEP THE DRAIN HOLE FROM FREEZING UP.
Apr 16, 2008 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
