Question about The Office Equipment & Supplies
Need help getting printer carriage where I can replace the ink cartridges
Posted by Harold Richard... on
CeeJay Mike
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Depending on the model of printer , once you turn it on and open the ink compartment door, it slides out.
Posted on Aug 22, 2019
5 Related Answers
Anonymous
SOURCE: Printer shows Carriage Jam, but I can't find it.
Push cartri9age to left about a 1/4", with finger pressure. Un-jammed my printer.
Posted on Apr 06, 2008
jai kumar
  • 79 Answers
SOURCE: hp 7210xi printer ink carriage circuit foil repair
hi its not a repairable. if u have warranty hp replacing a new printer in free of cost. other wise they giving some buy back offer.. better u contact ur local hp service provider.
Posted on Aug 18, 2008
Anonymous
  • 234 Answers
SOURCE: ink system failure erorr 0xc18a0306
It is a the flow of the ink into the printer which fails, and these error cannot be reset most of the times when you turn of the unit and oon back again if it works then it is good again, if not it is better to replace the All-In-One, If the printer is in warranty or extended warranty you will get a free replacement from HP, if not you can get a upgrade option wher you may get some discount from HP Tech support Call 1800 474 6836
Posted on Aug 29, 2008
Anonymous
  • 152 Answers
SOURCE: Printer won't print
That error usually means you need to change out the Ink waste tank filters located at the base of the printer - this is best changed by an actual HP tech - they can be very temperamental to remove properly. The cartridges probably leaked during storage. Next time, pull all of the carts out of the printer prior to storage.
Good luck, please rate this answer if you found it helpful.
Posted on May 11, 2009
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
SOURCE: to realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
Turn on printer, and just unplug power while carriage moving. Unplug USB. Then move carriage by hand.
Posted on Sep 15, 2009
I am low on ink and when I open lid to replace cartridge I get a screen error "Close The scanner unit" I have looked adjusted everything and re-started unit. Cannot clean or get to ink.
try this....Remove the old ink cartridge and install the new ink cartridge.
  1. Make sure the printer is turned on. ...
  2. Open the top cover of the printer. ...
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage...
  5. if this does not work go to this link it might help you out.....
How to replace cartridge Google Search
Oct 23, 2017 | The Office Equipment & Supplies
WHAT IS THE CARRIAGE CARTRIDGE
There are two different types of carriage units that you may be referring to depending upon the model printer you have. Older types of photo printers had two distinct carriages.
1. Carriage referees to equipment that travel left to right in your printer.
2. One is for the print heads that receive ink from your print cartridges and dispenses it to the paper that you are using.
3. The print head carriage that travels back and forth to accept replacement ink cartridges. Most of the time it is tucked to one side or the other and only travels when the printer is opened in a specific way to expose it for ink replacements.
In newer systems the print heads are built into the Ink cartridge, each color has it's own print head.
So in answer to your question the carriage cartridge is more than likely the container that you put your ink cartridge into. Unless you have an older printer and then it would or could be the carriage for either the print head or the ink. They some times need to be replaced. I had to replace that cartridge in an old HP2500 for as long as we had the printer. (4 years). Great machine high maintenance.
Aug 23, 2012 | HP Photosmart C7280 Printer
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Ink Cartridge problem? (HP designjet 5500 ps 42")
you are correct, this is usually caused by the contacts going bad on the carriage assembly. try cleaning the contacts, if this does not help, than you need to replace the carriage assembly. hope this helped.
Jun 17, 2009 | HP DesignJet 5500PS InkJet Printer
To realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
Jun 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
How do I replace an ink cartridge on NX400?
Assuming that that you have no errors preventing the cartridge change, press the "setup" button, use the arrow buttons to select "maintenance" and press the "OK" button. The carriage will now move to the replacement position. If you have an error condition and you need to access the ink carriage then swith on the printer and when the carriage begins to move across to the left simply pull out the power cable. The carriage can now be carefully pushed into position. Ensure that the carriage is pushed back to the right before turing power back on.
Hope this helps, please take a moment to rate this solution, thanks.
Apr 09, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Ink carriage
This is a tricky little printer. Here is your fix.
When you hold down the ink button for 3 seconds, the printer will perform a cleaning cycle.
But if you continue to hold the button for 10 to 15 seconds, it will then come ove to the opening where you can access the cartridges.
Apr 02, 2008 | Epson Stylus C44UX InkJet Printer
16 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
